2 blocks, frictions, and no numbers
  • Thread starter Thread starter musicfairy
    Blocks Numbers
9 replies · 5K views
musicfairy
Block A, with mass mA, is initially at rest on a horizontal floor. Block B, with mass mB, is initially at rest on the horizontal top surface of A. The coefficient of static friction between the two blocks is μs. Block A is pulled with a horizontal force. It begins to slide out from under B if the force is greater than:
A. mAg
B. mBg
C. μsmAg
D. μsmBg
E. μs(mA+mB)g
I came up with a couple of equations (that may not be right).
f = μmBg
f = F - mAaA
So I tried substitution and solving for F, but I can't get the right answer (E).
So what's the right way to do this problem?
The equation for frictional force is the coefficient of friction times the normal force. What is the normal force on block A?
Really? Draw a free body diagram.
Don't forget that block B is sitting on top of block A.
I did.
I have force F acting on mA.
mAg is directed down
mBg is directed down, and then up as a normal force
friction is in opposite direction of the 2 blocks
What am I doing wrong here? =(
The problem is that block A has block B on top of it. That means that the weight of block A is (Ma + Mb)g. What that means is that since block A is not accelerating down, it's normal force must be the same as the weight. Now do you understand?
Ok, I see now. So E says that F = μNA
But what does that mean? I thought friction is supposed to be the same for both blocks in this problem. This is getting more confusing.
The coefficient of friction is the same. The frictional force depends upon the normal force though. Because A has a greater normal force than B, it would produce a greater frictional force.
I see. Thanks for the explanations. Now I really need to study hard for that test.
