2 blocks, on ontop of the other
  • Thread starter Thread starter mujadeo
    Blocks
In the discussion, participants analyze the forces acting on two stacked blocks, A and B, with A having a greater mass. The primary question revolves around determining which force is greater: the gravitational force on block B or the force exerted by block A on block B. It is concluded that the force from block A on block B is greater due to A's larger mass, as gravity acts equally on both blocks. The conversation emphasizes that since the system is stationary, the net force must equal zero, confirming that all forces acting on both blocks and the system must balance out. Understanding these relationships is crucial for solving the problem accurately.
mujadeo
block A is ontop of block B.
block A more mass than B
Which force is greater magnitude, Force of gravity (mg (weight) on block B, or force of block A on B?
Wouldnt answer have to be Faonb because both blocks are subject to gravity?
Indirectly, your answer is correct, but you need to be a bit more specific in your reasoning. If you believe the force of gravity on A is equal to the force of A on B, you must state why.
Sorry, let me add a little more (important) info
Both blocks are stationary on level ground.
So let's say i want to know which force, on B has the greatest magnitude.
I have 3 forces acting On block B.
1) W (on b by earth)
2) F (on b by a)
3) N (on b by s)
Objects are not accerating (or moving) so I know Fnet=0
specifically,
Fxnet = 0 and
Fynet = 0
Also, there are no forces in x direction
For y I have
SumFynet = NyBS - mgyBE - FyBA= 0
So just purely from above equation, largest force would have to be the normal force of suface on B.
But how do i know which force is bigger, force on B by Earth (FyBE), or force on B by A (FyBA)??
thanks for any help
Good FBD of block B. But now to answer your question, you need to make a FBD of block A, then use Newton 3.
mujadeo, you clearly understand the process, so just finish your thought. The weight of B is the force from gravity. Since A is on top of B, and nothing is moving, the weight of A, would be the force acting on B. You know that A has greater mass than B, gravity is the same for both blocks, so which force is greater?
"You know that A has greater mass than B, gravity is the same for both blocks, so which force is greater?"
yeah that's how i was visualizing it, so thanks for the confirmation.
Obviously A would have the greater Force (gravity times its mass, (which is greater than B))
One other querstion though: Necause system is stationary (Fnet=0) that just means that all the forces must add to zero, right?
OK so does that mean when i do FBD for block A, that should = 0
and FBD for B that should be 0
and FBD for system A and B, that should 0 also, is that rght? ---thanks
Yes to all your questions.
