Engineering Solve 2 Loop RC Circuit: Find Q(topen)
The discussion focuses on solving a 2-loop RC circuit involving four resistors, a capacitor, and a battery, with specific values provided. After the switch is closed for a long time and then opened, the charge on the capacitor at 786 μs is sought. The maximum charge calculated is approximately 243 μC, but the challenge lies in accurately determining the time constant (τ) for the discharging circuit. The correct approach involves using the combined resistance of R2 and R3 to find τ, which is crucial for calculating the charge at the specified time. The conversation highlights the importance of correctly applying Kirchhoff's rules and understanding the exponential decay of the capacitor's charge.
acrimius
1. Situation and Variables:
A circuit is constructed with four resistors, one capacitor, one battery and a switch as shown. The values for the resistors are: R1 = R2 = 30 Ω, R3 = 66 Ω and R4 = 113 Ω. The capacitance is C = 64 μF and the battery voltage is V = 12 V. The positive terminal of the battery is indicated with a + sign.
2. Sub-question:
After the switch has been closed for a very long time, it is then opened. What is Q(topen), the charge on the capacitor at a time topen = 786 μs after the switch was opened?
3. Relevant Equations:
Kirchhoff's Loop Rule: \Sigma V_l = 0
Kirchhoff's Node Rule: I_i = I_o
V_C = \frac {q} {C}
For a discharging circuit:
q(t) = q_o e^\frac {-t} {\tau}
4. Attempt:
When the switch is closed initially and time goes to infinity, the capacitor charges up and reaches it's capacitance, which I found the max charge, qo to be about 243μC.
Then for a discharging circuit, we have the equation I gave above q(t). I believe my issue is finding tau, which is RC. I have been using R = R_1+R_2 but that hasn't been correct. I've tried different combinations of resistors but I'm not quite getting it.
Show your working for the capacitor charging voltage.
How to determine the capacitor's discharging path when the switch is an open circuit?
Q(∞)?
IC = 0 ∴ I1 = I2
Knowing this:
Loop for right hand side (I):
\frac {q} {C} = I_2R_3
Loop for left hand side (II):
V_b = I_2(R_1+R_3+R_4)
Therefore,
I_2 = \frac {V_b} {R_1+R_3+R_4}
plugging this into (I):
\frac {q} {C} = \frac {V_bR_3} {R_1+R_3+R_4}
then solve for q, which is just multiplying both sides by C.
The exactly answer they have for Q is 242.526315789474μC, which is what I got, and I have this number stored so I used it for my text calculation of find Q(786μs) from the equation q(t) = q_oe^\frac{-t} {\tau}
Also I figured the current go across the switch, so I assumed it would only traverse the right hand side, which is why I use R=R_2+R_3 the equation I originally posted is not what I had written, it was a typo on my part.
That's the discharge path. So you need to be able to write by inspection the exponential time equation for the capacitor voltage as it discharges. I see you almost have.
Are you able to calculate τ and finish this now?
NascentOxygen said:
That's the discharge path. So can you write by inspection the exponential time equation for the capacitor voltage as it discharges?
Right. So I have this equation:
q(t) = q_oe^\frac {-t} {R_2+R_3}
but because R2+R3 is so large in comparison to t=786μs, the e part is approximately 1, and so my calculator outputs nearly the same answer as I had before, which the website counts as incorrect
The time constant is the product of R and C. It needs to have units of seconds, or it wouldn't be a time.
Likes acrimius
NascentOxygen said:
The time constant is the producut of R and C.
Wow, that was a really dumb mistake on my part. Thanks for helping me though, I probably would have never realized that.
I thought you had it right in your first post ...
  • · Replies 17 ·
12K
