2 questions - series & inequalities
  • Thread starter Thread starter KLscilevothma
    Inequalities Series
KLscilevothma
2 questions -- series & inequalities
1. By differentiate the function 1/(1-x), or otherwise, show that
inf
[sum] n2/2n = 6
n=1
2) Given Holder's Inequality http://mathworld.wolfram.com/HoeldersInequalities.html(equation 4)
show that (attached file)
Mathematics news on Phys.org
exam questions
The attatchment is ready now. These 2 questions appeared in my exam but I don't know how to do them.
1.I do not know whether my solution is of help for you (it implies the basic knowledge of linear inhomogeneous recurrence) anyway I will present it.
Let
S=∑n=1 n2/2n (1)
and
S1(n)=∑k=1n k2/2k (2)
with S=limn->∞ S1(n) (3)
We have (equalities 3'):
n=1 ---> S1=1/(21)
n=2 ---> S1=6/(22)
n=3 ---> S1=21/(23)
n=4 ---> S1=58/(24)
n=5 ---> S1=141/(25)
n=6 ---> S1=318/(26)
Let now the general term of the sequence 1=a[1],6=a[2],21=a[3],58=a[ 4 ],141=a[5],318=a[6]... be a[n].
The closed form for the sum S1(n) is:
S1(n)=a[n]/(2n) (4)
To find a[n] it must be observed that (equations 4'):
n=1 ---> a[1]=1
n=2 ---> a[2]=6
n=3 ---> a[3]=21
n=4 ---> a[ 4 ]=58
n=5 ---> a[5]=141
n=6 ---> a[6]=318
and
a[2]-a[1]=1*2+3=5
a[3]-a[2]=5*2+5=15
a[ 4 ]-a[3]=15*2+7=37
a[5]-a[ 4 ]=37*2+9=83
a[6]-a[5]=83*2+11=177
a[7]-a[6]=177*2+13=367
a[8]-a[7]=367*2+15=749
a[n]-a[n-1]=2*{a[n-1]-a[n-2]}+(2n-1) (5)
If you have some experience with inhomogeneous sequences it's easy to find that we must seek for the closed form of a[n] a formula of the type:
a[n]=[A*n2+B*n+C]+D*2n
Introducing in (5) the equations 4' for n=1,2,3,4 and solving the system --->
A=-1
B=-4
C=-6
D=6
Therefore
a[n]={-1*n2-4*n-6}+6*2n (6)
Introducing (6) in (4) --->
S1(n)={{-1*n2-4*n-6}+6*2n}/(2n)} (4)
Finally
S1(n)=6-{(1*n2+4*n+6)/(2n)
and
S=6
I don't understand what happened I used the edit feature...
I don't understand what happened I used the edit feature...sorry.
1/(1 - x) = Σn=0..∞ xn
Differentiate both sides of the equation with respect to x, see if that gives you any clues. What if the numberator was just n instead of n squared; could you use the derivative you just computed to evaluate the sum?
I haven't worked through the second one before... I'll see if I can give a hint once I have time to figure it out.
Edit: changed the lower case sigma to upper case sigma
Thanks for reply.
metacristi, your method is pretty new to me but I'll try to understand that.
Originally posted by Hurkyl
1/(1 - x) = σn=0..∞ xn
:smile: The question clears up a bit now. I'll try to work it out after my calculus exam.
For question 2, please take your time, there's no rush. I'll try to work out the answer 2 days later, after my exams. Again thanks.
I'm terribly sorry
that I forgot to mention that a1,a2...an>0 such that [sum]r=1..n ar = 1 for the second question.
2.From what I've seen Holder's inequation hold only for (1/p)+(1/q)=1 and p,q >1 so that,I suppose,these are assumed true in the case of your problem too.
Let
Ar=(ar+1/ar)
Br=n-1/q
We have Ar,Br > 0 and Br <= 1 (if q > 1).
r=1 to n Ar*Br=∑r=1 to n n-1/q* (ar+1/ar) (1)
[∑r=1 to n (Ar)p]1/p=[∑r=1 to n (ar+1/ar)p]1/p (2)
[∑r=1 to n (n-1/q)q]1/q=(n*1/n)1/q=1 (3)
From Holder inequation,taking into account (1) (2) & (3) --->
[∑r=1 to n (ar+1/ar)p]1/p >= ∑r=1 to n Ar*Br=∑r=1 to n n-1/q* (ar+1/ar)
We have ar+1/ar >= 2--->
r=1 to n (ar+1/ar)p >= [∑r=1 to n n-1/q* (ar+1/ar)]p=n-p/q*[∑r=1 to n (ar+1/ar)]p
Thanks.
Originally posted by metacristi
Let
Ar=(ar+1/ar)
Br=n-1/q
&#8721r=1 to n Ar*Br=&#8721r=1 to n n-1/q* (ar+1/ar) (1)
[&#8721r=1 to n (Ar)p]1/p=[&#8721r=1 to n (ar+1/ar)p]1/p (2)
[&#8721r=1 to n (n-1/q)q]1/q=(n*1/n)1/q=1 (3)
[&#8721r=1 to n (ar+1/ar)p]1/p >= &#8721r=1 to n Ar*Br=&#8721r=1 to n n-1/q* (ar+1/ar)
&#8721r=1 to n (ar+1/ar)p >= [&#8721r=1 to n n-1/q* (ar+1/ar)]p=n-p/q*[&#8721r=1 to n (ar+1/ar)]p
I don't understand the second last step. Why do we need ar+1/ar >= 2. (I know it can be proved by AM>=GM)
In fact I found out how to do it yesterday but didn't have time to post my proof. I used a similar approach and here's my proof.
http://www.angelfire.com/freak2/anywork/ine2.jpg
Actually it is part (b) of a long question. I think I better post the whole question here.
http://www.angelfire.com/freak2/anywork/inequality.jpg
I am going to do part (d) today, and will ask again if I can't do it.
I think I got it...but it's quite simple...
if you know a)...then just put from 1/p+1/q=1, q=p/(p-1)...in d)...
sum[(Ar+1/Ar)^p]>n^(1-p)*[1+sum(1/Ar)]^p;
prove that sum(1/Ar)>n^2 this way...
sum(1/Ar)>n*(fact(1/Ar))^(1/n)=n*1/[fact(Ar)]^(1/n)>
> n/[sum(Ar)/n]=(n^2)/1...that's all...I think...
I think I have a solution for a)...
a) is equivalent to
{{sum[(Ar+1/Ar)^p]}^(1/p)}*n^(1/q)>sum(Ar+1/Ar);
write n this way ...
n=sum(1^q)...
{{sum[(Ar+1/Ar)^p]}^(1/p)}*{[sum(1^q)]^(1/q)}>sum(Ar+1/Ar);
which is exactly holder ineq for (Ar+1/Ar) and (1)...(hope it's correct... :))
I intended to underline the fact that ar+1/ar > 0 but we don't need it,indeed,in the demonstration since ar are all positive.
To prove a. suffices to write q as:
q=p/(p-1) and by studying the function q=f(p) --->
-when p < 0 ---> q is always greater than 0 ---> pq < 0.
-when p belongs to (0,1) ---> q is always negative ---> pq < 0.
-when p belongs to (1,+∞) that's it when p > 1 we have q greater than 0 ---> pq > 0 q.e.d.
My solutions to c. and d. (slightly different than those of Bogdan) are:
c.
You must observe that:
[a1+..+an]*[1/a1+...+1/an] ≥ n+n[C]2*2=n+{n!/[(n-2)!*2!)]}*2=n^2
where I used:
{ar/ak}+[1/{ar/ak}] ≥ 2 (obviously (A+1/A) ≥ 2 when A > 0))
and n[C]2=combinations of n,2=n!/[(n-2)!*2!)]
d.
[sum]r=1 to n ar = 1,
b. by replacing q with p/(p-1),
c. [sum] 1/ar ≥ n2 ---> [sum] ar+1/ar=[sum] ar+[sum] 1/ar ≥ 1+n2,
---> the required inequality.
[edited to change the layout of the demonstration]
1/(1 - x) = &Sigma;n=0..&infin; xn
1/(1-x)2 = &Sigma;n=0..&infin;nxn-1
sub x=1/2, then multiply both sides by 1/2
&Sigma;n=0..&infin;n/n2
Take the 2nd derivatives on both sides of
2/(1-x)3=&Sigma;n=0..&infin;(n2-n)xn-2
sub x = 1/2 and multiply both sides by 1/4
The result follows.
edit: metacristi, I don't know inhomogeneous sequences
Thanks
Bogdan, I used the same method as you do (see my post above yours).
I now understand these 2 questions, thanks for your help.
Yes, it's simple. I knew how to do part a, b and c when I was at home and used about 15 minutes to finish them (exclude part d), but not in exam.. I was too nervous, I only had 20 minutes to think whether to choose this question or the other and finish it. :frown: I only had 1 day to revise for this algebra exam while I had put aside algebra for 6 months and studied calculus. (finding excuses to cover up my stupidity! )
