Automotive 2001 chevy 3500 pickup cant keep the compressor on
  • Thread starter Thread starter wlr483
    Compressor
The 2001 Chevy 3500 pickup's A/C compressor fails to activate despite replacing components and checking the fuse. Jumping the compressor works, indicating potential issues with the electrical circuit. A likely cause is a shorted wire that could be blowing fuses, or a malfunctioning A/C clutch relay located in the power control module. Additionally, the truck's Vref line, which supplies multiple sensors for the climate control system, may be compromised, affecting overall functionality. Proper diagnosis of the wiring and sensors is essential for a reliable fix.
wlr483
i have a 2001 chevy 3500 pickup i can't get the a/c compressor to kick on i replace everything and checked fuse i can jump it and it wil works, but i need it done right does anyone know what it might be
Why would you ask the question in a mechanical engineering forum? Go ask the question to people who are familiar with your specific truck, like a Chevy trucks forum!
If I understand you correctly - and if you made sure every electrical components are OK -, it sounds like you have a shorted wire that blows up your fuse.
If that is the case - and with the spaghetti-like wiring harnesses of today making it difficult to find the faulty wire - usually the easiest solution is to bypass the defective circuit by disconnecting it and putting another wire.
Is there 12v at the compressor with ac on ? If not , assuming there is the proper level of 134a , I would look at the pressure switch
Jack Action has a good point ,,,but before by pass, did you test the A/C clutch relay? This is a 5 terminal switch located in the power control module...if it checks out ok, it is likely in the dash board AC switch...or you burnt a wire in the miles of wiring...ugggg
Anything else wrong with the car.
I believe the truck mentioned has a Vref line that supplies multiple sensors.
These sensors include the climate control system and are used to determine charge pressure, temperature, and air door position.
If any sensor on that line is compromised, it can affect anyone of the systems that use a sensor on that line.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
