Medical Velocity of blood through aorta
  • Thread starter Thread starter engineer23
    Blood Velocity
The velocity of blood through the aorta can be calculated using cardiac output, which is typically around 5 L/min, by converting this to cubic feet per minute and dividing by the aorta's cross-sectional area. The aorta's radius varies, and blood flow is pulsatile, complicating the correlation between flow rate and velocity. Peak flow velocity is approximately 100 cm/s, but this value can fluctuate based on body position and metabolic state. The aorta's distensibility means its cross-sectional area is not constant, further affecting velocity calculations. Understanding these dynamics is crucial for accurate ultrasound probe design.
engineer23
Does anyone know the velocity of blood through the aorta? I have a problem that involves an ultrasound probe and I need to know which velocites of blood I should design for. I know cardiac output is stroke volume x heart rate, but a) what are the range of values for stroke volume and b) how do I correlate flow rate to velocity?
Thanks!
Biology news on Phys.org
OK, I think I had an epiphany since I posted a few minutes ago...Cardiac output is 5L/min...I can convert this to cubic feet min and divide by the cross sectional area of the aorta to get a velocity. But what are the upper and lower limits on the radius of the aorta?
The blood flow in the aorta is highly pulsatile and even goes retrograde during part of diastole. Also the aorta is highly distensible (in healthy people) and so the cross sectional area of the aorta is not constant either. Basically, your epiphany is a nice idea, but the reality is a little more complicated.
A good rule of thumb is that the peak flow velocity is about 100 cm/s, but again this is the peak velocity not the average velocity. Also, the peak velocity depends on orientation (standing vs. supine) and metabolic state (resting vs. exercise) http://www.pubmedcentral.nih.gov/articlerender.fcgi?artid=481953
On a side note, the earliest definitions of kinetic energy and the first suggestion of the law of conservation of mechanical energy arose from measurements that Bernoulli was performing on the flow velocity of blood (when he noticed that if you cut off a limb, the height to which the blood spurted out was proportional to the square root of the flow speed :biggrin:).
I've been reading a bunch of articles in this month's Scientific American on Alzheimer's and ran across this article in a web feed that I subscribe to. The SA articles that I've read so far have touched on issues with the blood-brain barrier but this appears to be a novel approach to the problem - fix the exit ramp and the brain clears out the plaques. https://www.sciencealert.com/new-alzheimers-treatment-clears-plaques-from-brains-of-mice-within-hours The original paper: Rapid amyloid-β...
https://www.discovermagazine.com/the-deadliest-spider-in-the-world-ends-lives-in-hours-but-its-venom-may-inspire-medical-miracles-48107 https://en.wikipedia.org/wiki/Versutoxin#Mechanism_behind_Neurotoxic_Properties https://www.sciencedirect.com/science/article/abs/pii/S0028390817301557 (subscription or purchase requred) The structure of versutoxin (δ-atracotoxin-Hv1) provides insights into the binding of site 3 neurotoxins to the voltage-gated sodium channel...
10K
9K
