Castaway
Polarization and Quantum Theory -- confused
This is what I'm getting hung up on:
If you take a piece of vertically polarized glass and place it in front of a piece of horizontally polorized galss then NO light passes through the second glass because the light is at 90 degrees to the horizontal polarizer once it it passes the vertical polarizer.
If we place a third polarizer between the two and set it at 45 degrees to the other two then a quarter of the light entering the vertical polarizer will emerge from the horizontal polarizer (as opposed to none as before). 50% of the light that passed the verticle polarizer passes the middle polarizer and then 50% of this light (25% of the original light) passes through the horizontal polarizer.
The explanation given (as I understand it anyway) is that the light can get through the polarizer that is set at 45 degreed because of the light's "probability wave" and the inherent uncertainty about exactly what polarization the light has.
I guess that's the part I don't get, how can there be ANY non zero probability that light that ISN'T vertically polarized exists on the opposite side of the vertical polarizer. If the light got through the polarizer then it MUST be vertically polarized (otherwise it simply would not have passed, no?). So doesn't the vertical polarizer act as "detector" of sorts (since we know that only ONE polarity can pass)? If so shouldn't there be a 100% probability that the light traveling between the vertical polarizer and the one set at 45 degrees is vertically polarized?
I guess I'm not understanding how a vertical polarizer can trasmit light that could then pass through a polarizer at 45 degrees to the vertical one.
Confused... help!
Thanks
*CA*
Confused... help!
Thanks
*CA*
