SO(32) in Superstring Theory: Physical Meaning
  • Thread starter Thread starter arivero
    Strings
arivero
Could someone tell about the physical meaning of these SO(32) groups in superstring theory?
I am under the impression that it is a symmetry of the quantum superstring, but that it is not a symmetry of any underlying classical model, is it? Because if it is so, it is very different of the GUT groups, which are also symmetries of the field Lagrangian.
You are right, the gauge degrees of freedom in string theory appear only on the quantum level. But in a sense, it is not much different from that in particle physics. Namely, you can view a classical gauge field as a first quantized wave function, so you can say that the gauge degrees of freedom of particles also appear only at the quantum (first quantized) level. By the way, most of the results in string theory are expressed in the first quantized language, while second quantization of string theory (string field theory) is not well understood and there are even indications that string field theory is not the correct approach.
What are all these papers by this guy Shnabl, then?
Yep, I though, while writing the question that this was the answer. But I asked anyway because I am not sure. One gets the feeling that gauge fields, or at least abelian gauge fields, can be recovered in a classical level, while the SO(32) etc of string theory seem to be intrinsically quantum. Part of the answer seems to lie in
N. Marcus and A. Sagnotti, “Group Theory From ’Quarks’ At The Ends Of Strings,”
Phys. Lett. B188 (1987) 58. http://www.slac.stanford.edu/spires/find/hep/www?j=PHLTA,B188,58
Further references:
http://www.roma2.infn.it/stringaperta/berlin.ps
http://motls.blogspot.com/2007/08/answering-few-string-related-questions.html
http://arxiv.org/abs/hep-th/0208020
http://arxiv.org/abs/hep-th/0204089
http://arxiv.org/abs/hep-th/0203098v1
This is an alert about a claim regarding the standard model, that got a burst of attention in the past two weeks. The original paper came out last year: "The electroweak η_W meson" by Gia Dvali, Archil Kobakhidze, Otari Sakhelashvili (2024) The recent follow-up and other responses are "η_W-meson from topological properties of the electroweak vacuum" by Dvali et al "Hiding in Plain Sight, the electroweak η_W" by Giacomo Cacciapaglia, Francesco Sannino, Jessica Turner "Astrophysical...
https://arxiv.org/pdf/2503.09804 From the abstract: ... Our derivation uses both EE and the Newtonian approximation of EE in Part I, to describe semi-classically in Part II the advection of DM, created at the level of the universe, into galaxies and clusters thereof. This advection happens proportional with their own classically generated gravitational field g, due to self-interaction of the gravitational field. It is based on the universal formula ρD =λgg′2 for the densityρ D of DM...
