I violate law of energy conservation
The discussion explores a hypothetical scenario involving a helium balloon that could potentially violate the law of energy conservation by generating energy from its ascent. It suggests that the potential energy gained from the balloon's height could be significant, leading to thoughts of perpetual motion. However, participants quickly point out that the energy required to pump and deflate the balloon would negate any energy gained from its fall. The idea of using a sealed tube with lighter air to assist in bringing helium back down is mentioned but ultimately dismissed due to the impracticality of energy requirements. The consensus is that the pursuit of perpetual motion in this context is futile and not supported by physics.
atom888
Let's say we have a helium balloon carrying total weight of 1 kg.
We set up 2 stations. Pumping station on the ground and deflating station at certain height.
We pump the balloon until it start to float up. We catch it at deflating station at height H.
Now the energy we gain is potential energy of the falling balloon which is mGH.
The energy require for pumping and deflating a balloon is set! If any.
The height H can stretch as high as you want to! => mGH is a linear increasing function.
Cool -- perpetual motion finally!
But seriously, if this is a closed cycle that runs continuously, how do you get the helium back down to the ground to keep refilling the balloon...? Pump it, right? And the energy you could get out of the balloon motion gets used up (plus more) in the helium pumping.
Oh well, still no perpetual motion.
Well, there's no problem in getting the helium back down. Just make a sealed tube that contain air lighter than helium and let gravity do the work. Yeah, still the sticky point is the pumping the balloon part. I suspect the energy require to pump the balloon is theoratically exact as the maximum height the balloon would reach. Oh well, I'll find another way to break that law.
Your time really would be better spent on another pursuit. Right now, you're playing a lottery with no jackpot!
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
