250VDC Line, Transient detection
In the discussion about recording both DC and AC transients on a 250VDC line, participants share insights on historical and modern instrumentation. A member recalls using a Sangamo transient capture machine that combined FM tape recording with V/F converters to capture signals, highlighting the evolution from analog to digital technology. They suggest searching for "power transient recorders" for utility-scale solutions, which can be expensive. For budget-conscious projects, alternatives like Arduino or Raspberry Pi are recommended for single-channel monitoring. The conversation emphasizes the shift towards microcomputers and software solutions for contemporary transient detection needs.
EEFinder
Any of you guys know of any instrument to record both the DC and at the same time the AC transient of a DC line.
Thanks.
Thanks.
Wow. Telemetry
Shades of yesteryear.
Forty plus years ago we put a Sangamo brand transient capture machine in the power plant to record 60 hz AC and currents. We "souped up" a couple of their amplifiers so they'd handle DC as well.
That machine was based on a 32 channel FM tape recorder where each signal to be recorded was handed to a V/F converter, which frequency modulated a carrier in audio range . Playing the tape back into a F/V converter reproduced the original signals. For one special DC signal I built a V/F out of a LM566 that worked fine. IRIG-B was the standard that defined FM frequencies for telemetry back then.
Very soon afterward computers , especially mass storage, had progressed to the point that fast sampling ADC's and memory did the job way better and cheaper. And no tape drives to maintain.
I don't know what size project you're into.
Try searching some keywords from suppliers who make "power transient recorders". Google returns lots of hits. They tend to be utility scale with scores of channels tens of thousands of dollars.
If it's just one channel you need to monitor on a budget it sounds like a project for Arduino or Raspberry Pi.
One could do it with a VCO and an 8 track tape deck...
https://www.egr.msu.edu/eceshop/Parts_Inventory/datasheets/lm566.pdf
but only if you're really into "retro" and "steampunk" ( c'mon old jim act your age)A microcomputer is the way to go. Surely there's one out there, maybe Labview or something.. Sorry, i just don't know where. I am obsolete.old jim
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
