Can A and B be equal in the region between x=0 and x=a?
frankcastle
write the solutions to the S.E in regions x<o and x between o and a
C:\Users\karthik\Desktop
I believe psi(x)= e^ikx+Re^-ikx in x<0
and psi(x)=Ae^iqx+Be^-iqx for x b/w o and a.
My question is, since there is complete reflection occurring at x=a, can A=B in region x b/w 0 and a? If so, there will be destructive interference in the region, giving R=1, which is what we are asked to prove in the question. Is this approach of equating coefficients of wave traveling in +-x directions in this region applicable?
You haven't defined your potential over the domain of x. My guess based on the info given is that the potential V(x) = infinity for regions less than or equal to x = 0 and greater than or equal to x = a.
To solve for the equations, you must impart the boundary conditions on the general solution for the wave function. So, psi(x) must vanish at x = 0 and x = a. For example, suppose that psi(x) = Asin(kx) + Bcos(kx) is a general solution to the time-independent schrodinger equation. Now, for the potential I expressed in the first paragraph, we must have psi(x) = 0 at x = 0 and x = a. When x = 0, psi(x = 0) = B; therefore choose B = 0, and now psi(x) = Asin(kx). Now fit the wavefunction to x = a: psi(x=a) = 0 = Asin(ka). Under what conditions for k (the angular wavenumber) will the sine term vanish?
You can apply this idea to your solutions. As a check, verify that your solution satisfies the time-independent schrodinger equation.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
