3 balls in a moving mechanics problem
41 replies · 5K views
Manolisjam
Consider 2 balls A,B on the same line . and they are connected to a third one G with a rope L. AG, AB. now the system monves in the effect of the mass of G and its projection to the line AB is in the middle. No friction. mass of A=mass of B=m and mass of G=2m
.FInd the time of impact and the velocity of G at that time A-B move only on the x axes.
Dont understand what it means the system moves on the effect of the mass G. Also I know the only forces are From the rope. 2 on the G ball and 1 in each of the balls.I understant i have to apply conservation law of energy but how? What is the potential energy(what if the force) ?
.jpg
    .jpg
I think it means that mass Γ is pulling the the other two masses towards each other as it drops down. If masses A and B are moving horizontally does their potential energy change? What about mass Γ?
so what is the force acting on G 2mg?
Yes, plus the tension from each string.
So far so good?
Manolisjam said:
So far so good?
Nope. Why is T1 = mg = T2? Furthermore, the tension is not constant as mass G descends. If I were you, I would stick to the original idea of energy conservation and not try to derive the equation of motion. Note that the time of impact depends on how far apart masses A and B are when they are released (I assume) from rest. Does the problem give that distance?
From symmetry? ALso why isn't the tension constant? the rope isn't elastic .
my Tx isn't constant
IM really confused...
Symmetry demands that the tensions be equal, T1 = T2, but not that they are equal to mg which is what you had.
I agree, but neither Ty is constant. Is the acceleration constant or does it depend on θ?
neither Ty is constant what does that say? Also how do you break up a force equal=2mg to 2 equal forces? ANd the acceleration depends on θ
You have to consider two free body diagrams, one for the hanging mass G and one for A. You get two equations of motion. Note that the accelerations of A and G are different but related through angle θ. That relation you have to derive starting from y = (L2 - x2)1/2.
dont get it. COuld you please post a pic with a complete answer I am trying 2 days now.
A, B only move in x don't fall
why T1=T2=mg is wrong?
Sorry, it's against forum rules to post complete answers.
Because in the vertical direction, the forces acting on mass G are 2Ty up and 2mg down. What is the net force on G? What is the net force equal to according to Newton's 3rd law?
You don't really need to find T. You want to write two equations involving T the masses, and the accelerations. These would be Fnet = Ma in the vertical and horizontal directions. So in the vertical direction, you get 2T cosθ - 2mg = - 2maG. Can you write an analogous equation for the horizontal direction?
mind that A-B don't move on the y axes
ALso is it possible to find T without knowning a_g ? just asking cause i want to undersand what is happening
Also i found Ty on an angle θ' not on θ
I understand that. However, there is horizontal tension Tx that accelerates A and B in the horizontal direction.
No
No, because they are related through Newton's 2nd Law equation. What's happening is that as mass G descends, it pulls the other masses together until they collide.
It doesn't matter because they are related, θ + θ' = 90°. You can choose either one.
i osted my progress so far.
Let's say the gravitational potential energy U is zero when all three masses are at the same height and mass G is at the origin O. What is the potential energy when the distance between A and B is 2x and mass G is distance y below the origin? How are x and y related?
so all i did is a waste?
ive been trying 2 days now straight .l . I've asked other people no1 will give me a full answer so i can study it and understant it and learn from it . because that the policy .. i give up...
I am sorry you feel that you should give up. In this forum we do not give answers but guide people to the answers so they could learn how to do things on their own. I tried pointing you in the right direction when I posted #26, but instead of following my lead and answering my questions, you became concerned about your "wasted" time. So be it, I will not waste any more of your time.
sorry for being rude I am just frustrated.. really appreciate you wasting your time with me.
