I-Beam load capacity question, what beam for 70 tons?
The discussion centers on the need for an I-beam to support a locomotive's weight in a service pit designed to be 10 feet wide. Each axle of the locomotive truck exerts a load of approximately 35 tons, totaling around 70,000 lbs. The user seeks guidance on selecting an appropriate I-beam that can handle this load with a deflection of less than 1 inch. However, the conversation is halted with a reminder that such construction work requires the expertise of a registered professional engineer. The thread is subsequently locked to prevent further discussion.
gwrassiniboia
Hi,
I'm sorry if there have been loads of posts about this, but I'm hoping someone can help me out here.
I'm making a pit to service a locomotive, this pit needs to be 10 feet wide (width along the rails), inorder to support the weight of the locomotive we have decided to run I-Beams under the rail to help the rail carry the weight. The weights distributed along the rails are as follows:
Each locomotive has 2 trucks, each truck has two axles, each axle has a weight load of 35 tons (appx 70,000 lbs).
The pit will only be wide enough for one truck, but two axles.
< 10' of I-Beam and Rail >
:~points where weight will~:
:~be resting ~~~~~~~~~:
(sorry for the crude picture)
The weight of the axles will rest on the outer edges of the beam for the most of the time, but we will need to drive over the middle of the beam at a very slow speed, so for it to hold the weight is critical (sometimes we'll need someone in the pit while the locomotive is moving).
What I'm looking for is what I-beam would be suitable, deflection must be less than 1 inch.
Any help with this would be greatly appreciated.
It is illegal for you to do this sort of construction work without the assistance of a registered professional engineer and it would be illegal for anyone on this site to help you off-the-cuff.
Hire a professional structural engineer.
Thread locked.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
