Laboratory technician drops a 0.0850kg sample of unknown solid
  • Thread starter Thread starter Larrytsai
    Laboratory Solid
A laboratory technician dropped a 0.0850 kg sample of an unknown solid at 100.0 degrees Celsius into a calorimeter containing 0.200 kg of water and 0.150 kg of copper, initially at 19.0 degrees Celsius, resulting in a final temperature of 26.1 degrees Celsius. The discussion revolves around calculating the specific heat of the unknown solid using the principle of heat transfer, where the heat gained by the calorimeter and water equals the heat lost by the solid. Participants emphasize the importance of using specific heat values for copper and water from reference tables. The heat balance equation is suggested to relate the heat gained by water and copper to the heat lost by the solid. The conversation concludes with an acknowledgment that while the temperature changes are not equal, they are proportional to the heat transferred.
Larrytsai
A laboratory technician drops a 0.0850kg sample of unknown solid material, at a temperature of 100.0 degree celcius, into a calorimeter. The calorimeter can, initially at 19.0 degrees celcius, is made of 0.150kg of copper and contains 0.200kg of water. The final temperature of the calorimeter can and contents is 26.1 degrees celcius. Compute the specific heat of the sample.
The only thing i have so far is
Qsys= -Qsurr
but I am stumped with the 2 specific heat variables
Not sys and surr, I would rather go for gain=lost.
I suppose you should check both specific heats of copper and water in tables.
Being calories and degrees C he ought to know that for water roughly.
ChemBuddy chemical calculators - buffer calculator, stoichiometry calculator
www.ph-meter.info - ph meter, ph electrode
i'll be so grateful if you can help me for this problem:
a 30.14-g stainless steel ball bearing at 117.82 c is placed in a constant-pressure calorimeter containing 120.0 mL of water at 18.44 C.if the specific heat of the ball bearing is 0.474 J/g.c, calculate the final temperature of the water.assume the calorimeter to have negligible capaity.
It is again simple heat gain (by water) equals heat lost (by ball). Assume final temperature to be Tfinal and write equation for a heat balance. You will get equation with one unknown. That's all.
methods
chemical calculators - buffer calculator, concentration calculator
www.titrations.info - all about titration methods
thank you so much,,i got the idea, but I'm still thinking about if q(water) equals q(ball), can we
prove that (Delta Temp) for water equals (Delata Temp) for the ball!
No, but both changes in temperature are directly proportional to the amount of heat transferred.
