3D Electric field vector calculation for two parallel plates
The discussion focuses on calculating the electric field vector between two parallel metal plates using voltage measurements at 12 specific points. The key equation utilized is E = V/d, where E represents the electric field vector, V is the voltage at each measurement point, and d is the distance from the midpoint of the rectangular box to each of the measured points. The challenge lies in accounting for the non-infinite size of the plates, which affects the direction of the electric field vector. Participants provided guidance on applying this equation to derive the electric field vector accurately.
  • Understanding of electric field concepts
  • Familiarity with voltage measurements
  • Knowledge of basic physics equations, specifically E = V/d
  • Ability to perform spatial calculations in three dimensions
  • Research methods for calculating electric fields in finite-sized conductors
  • Explore numerical methods for electric field simulations
  • Learn about the impact of boundary conditions on electric field calculations
  • Investigate software tools for visualizing electric fields, such as COMSOL Multiphysics
Physics students, electrical engineers, and researchers involved in electromagnetism and electric field analysis will benefit from this discussion.
w888k
For two metal plates parallel to each other, when voltages was applied to them, there is an electric field in between. I measured the voltage at 12 points (known x,y,z) between them. these 12 points formed a rectangular box (three on each of four lines, which is perpendicular to the plates). Now I want to calculate the electric vector at a point along a line (also perpendicular to the plates) in the middle of the rectangular box. Since the the plate is not of infinite size, the electric field mat not be precisely perpendicular to the plates. so I want to calculate the actual electric field vector. Any body could give me some directions? Thanks.
You can use the 12 points that you have measured to calculate the electric field vector at the point in the middle of the rectangular box. You will need to use the equation E = V/d, where E is the electric field vector, V is the voltage at each of the 12 points, and d is the distance between the point in the middle of the rectangular box and the 12 measured points. By using this equation for each of the 12 points, you can calculate the electric field vector at the point in the middle of the rectangular box.
  • · Replies 58 ·
  • · Replies 18 ·
