3D Transformation of Rectangle to a Plane
DukeLuke
Let's say you have four points that define a rectangle in the xy plane centered at the origin (with the x,y axes bisecting the sides). How can you transform these points so that the rectangle lies in an arbitrary plane (defined by a point p and a normal vector n) so it is centered about point p. I realize some orientation of the four points in this plane is needed for a unique transformation, but I'm stuck even getting an arbitrary orientation of these four points in the plane.
I'm thinking the correct approach may be to rotate the four points about the origin until the plane they create is normal to n, and then move them to the correct position. At this point I'm not even sure how to rotate the points until the plane they create is normal to n.
First you need to rotate the rectangle so that
It's on the arbitrary plane. This can be done
Using a rotation matrix whose rows or cols
Are the components of the orthonormal basis
Vectors: normal, binormal and their cross product.
Next is to translate so that its center is the point p.
This is easily done by translating using a vector equal
to (p - rectangle origin). The details are an exercise for u :D
Try it yourself first :)
got it, thanks!
##\textbf{Exercise 10}:## I came across the following solution online: Questions: 1. When the author states in "that ring (not sure if he is referring to ##R## or ##R/\mathfrak{p}##, but I am guessing the later) ##x_n x_{n+1}=0## for all odd $n$ and ##x_{n+1}## is invertible, so that ##x_n=0##" 2. How does ##x_nx_{n+1}=0## implies that ##x_{n+1}## is invertible and ##x_n=0##. I mean if the quotient ring ##R/\mathfrak{p}## is an integral domain, and ##x_{n+1}## is invertible then...
The following are taken from the two sources, 1) from this online page and the book An Introduction to Module Theory by: Ibrahim Assem, Flavio U. Coelho. In the Abelian Categories chapter in the module theory text on page 157, right after presenting IV.2.21 Definition, the authors states "Image and coimage may or may not exist, but if they do, then they are unique up to isomorphism (because so are kernels and cokernels). Also in the reference url page above, the authors present two...
When decomposing a representation ##\rho## of a finite group ##G## into irreducible representations, we can find the number of times the representation contains a particular irrep ##\rho_0## through the character inner product $$ \langle \chi, \chi_0\rangle = \frac{1}{|G|} \sum_{g\in G} \chi(g) \chi_0(g)^*$$ where ##\chi## and ##\chi_0## are the characters of ##\rho## and ##\rho_0##, respectively. Since all group elements in the same conjugacy class have the same characters, this may be...
