Superluminal instantaneous influence
  • Thread starter Thread starter scope
    Superluminal
scope
hi,
it is well known that after measurement, there is a superluminal instantaneous influence (but not really communication) in entanglement.
I wonder if such influence also happens everytime before measurement as well?
i would be very grateful to read your reply!
It's not "influence" (which is another term for "causation"), but rather correlation.
Correlation and causation are very distinct concepts.
anyway, the question is: does the same happen both before and after measurement?
One can't correlate the results of measurements before those measurements
have been performed, i.e., before the results exist.
ok, and what if, before the measurement, the state of the first particle is modified. would the state of the second particle in entanglement be modified to verify again the correlations?. in other words, does the EPR effect applies even without measurement?
scope said:
ok, and what if, before the measurement, the state of the first particle is modified. would the state of the second particle in entanglement be modified to verify again the correlations? in other words, does the EPR effect applies even without measurement?
Correlation, expectation values, etc, etc, are concepts that apply to an ensemble.
But you're trying to think of them in the context of a single instance of an experiment.
I don't think there's much more I can usefully say here in a few lines except "invest
in a copy of Ballentine". He discusses all this stuff much better and more comprehensively
than I could ever do here.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
