Closed loop vs open loop resistance magnet drop demo
The discussion centers on the behavior of a magnet dropped through a copper pipe, which falls slower than expected due to electromagnetic induction. The original poster speculates that replacing the copper pipe with insulated copper wire in a closed loop configuration might further reduce the fall rate compared to an open loop setup. They suggest that the closed loop would generate an opposing magnetic field due to induced current, enhancing resistance. Participants note that the phenomenon resembles the resistance felt when moving a hand through water. Overall, the conversation explores how different configurations of conductive materials affect the fall rate of a magnet.
Robin Hooper
Hello everyone, curious about something here.
I saw a demonstration lately were a magnet was dropped down a copper pipe and the magnet dropped very much slower than expected. What I got to thinking was, if you replaced the copper pipe with the same quantity of insulated copper wire in a closed loop configuration and compared the fall rate to an open loop setup. Would the magnet fall slower in a closed loop than the open loop setup? My intuition would say that the closed loop coil would farther reduce the fall rate because you now have electron flow(current) which would setup its own magnetic field adding to the resistance of the copper wire.
Thanks
Did anyone offer an explanation of why the magnet fell slower in the copper tube. Do you have any idea? What is your guess about why an open loop or closed loop may affect the magnet differently?
No, I was just a passer by, I had no oppertunity to ask. I understand that the magnetic field behaves much like when you run your open hand though water, there is a resistance felt. An open loop would be very much like the copper tube, magnetic field going through copper. I suspect that a closed loop would setup an opposing current futher reducing the fall rate in addition to the magnet moving through the copper, but that would just be a guess.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
10K
