Trying to make fuel vapor supply system
The discussion centers on creating a fuel vapor supply system for a gasoline engine, with concerns about safety and simplicity. Suggestions include using an ultrasonic mister, although there are worries about potential sparks. Heating the fuel to its evaporation temperature is another idea, but the simplest method may involve using a basic carburetor. One proposed solution is to run the fuel pump back into the tank to agitate the fuel and create vapor, while also incorporating a copper tubing coil to heat the fuel. Additionally, mixing HHO with the fuel vapor is mentioned as a potential enhancement.
Qaiphyx
Originally posted this in the wrong section. What would be the most basic and solid way of doing this for a gasoline engine? I've thought about using a ultrasonic mister but I am afraid that there may be a potential for a spark, don't want to blow up. I've also tossed around the idea of heating the fuel to its evaporation temps, but not sure what the simplest way would be to do this. Any ideas?
Take and run your fuel pump back into the tank to agitate the fuel to produce vapor, and run a coil of copper tubing thru your fuel tank from the radiator to heat the fuel, use your vapor return to the intake after all the censors. Do not deactivate the injectors.
You may also add HHO to mix with the fuel vapor.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
