Connect 3.55mm Leads w/o Solder: Male TRS Connector
  • Thread starter Thread starter geoduck
To connect leads to a male TRS connector without soldering, users can look for in-line male 3.5 mm stereo plugs that allow for screw connections. These connectors can be found at electronics stores like Radio Shack or local hobby shops. While soldering is typically recommended for a secure connection, solderless options are available, albeit often at a higher cost. It's essential to ensure that the connector is compatible with the circuit leads being used. For those unfamiliar with soldering, exploring solderless alternatives is a practical solution.
geoduck
I need to connect the leads of a circuit to a male TRS connector (3.55 mm). How would I do this? When I go to the store, all I see are male-male 3.55 mm connectors, which would mean I would have to solder the ends of the circuit to one of the male ends, which seems awkward.
Is there an easier way to do this, preferably without the need for solder? Is there a 3.55 mm connector that is male-to-wires, where you can just attach your three wires to the connector, and then plug the male into whatever device you want which would connect the three wires to the device via the male?
You should be able to find in-line male 3.5 mm stereo plugs that allow you to solder some pig-tails on. If you're in the States, you should still be able to get these at Radio Shack. Better place to go would be your local electronics hobby shop, however. I'd put on a little heat shrink (available at the above-mentioned places, or any automotive / hardware supply store) over top of the soldered connection to keep things from shorting out.
I hope I'm not patronizing here, but if you're using a soldering gun or high powered iron, you should buy / borrow a more suitable soldering iron.
Thanks. You're not patronizing - I'm utterly clueless when it comes to electronics (and don't know how to solder or own a soldering iron). I was able to find a solderless plug, one that used screws, but it was a bit more expensive because it was gold-plated. It's here:
http://www.radioshack.com/product/index.jsp?productId=2103990
Obviously someone who was competent would just buy a cheaper plug and use solder, but because of my deficiencies I was looking for a very specific product.
Thanks.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
