Proper definition of world lines in Galilean and Minkowskian spacetime
Wox
I posted several questions on Galilean and Minkowskian spacetime on this forum lately, but I just don't seem to be able to get a real grip on things. I noticed that the core of my problems mostly arise from the definition of world lines. Therefore I tried formulating a definition of them in both spacetime's and my question is whether these definitions are correct/complete.
1. In Galilean space, world lines are defined as curves (continuous maps)
<br /> \bar{w}\colon \mathbb{R}\to \mathbb{R}^{4}\colon \tau \mapsto (t(\tau),\bar{x}(\tau))<br />
for which a curve in Euclidean space
<br /> \bar{x}\colon \mathbb{R}\to \mathbb{R}^{3}\colon \tau \mapsto \bar{x}<br />
and an injective map (because a world line shouldn't contain simultaneous events)
<br /> t\colon \mathbb{R}\to \mathbb{R}\colon \tau \mapsto t<br />
We used the fact that \mathbb{R}^{3} has the Euclidean structure and that a basis was choosen in \mathbb{R}^{4} so that all vectors (0,\bar{x}) form a subspace of Galinean space \mathbb{R}^{4} which is isomorphic with \mathbb{R}^{3} (i.e. Euclidean inner product defined on this subspace).
2. In Minkowskian spacetime with signature (-+++), world lines are defined as differentiable curves
<br /> \bar{w}\colon \mathbb{R}\to \mathbb{R}^{4}\colon \tau \mapsto (x^{0}(\tau),x^{1}(\tau),x^{2}(\tau),x^{3}(\tau))<br />
which are timelike (because a world line shouldn't contain simultaneous events) meaning that the velocity of the world line is a timelike vectors (\eta(\bar{w}&#039;,\bar{w}&#039;)&lt;0) or in other words
<br /> (\frac{dx^{1}}{d\tau})^{2}+(\frac{dx^{2}}{d\tau})^{2}+(\frac{dx^{3}}{d\tau})^{2} &lt;(\frac{dx^{0}}{d\tau})^{2}<br />
We used the fact that \mathbb{R}^{4} has an inner product \eta which is non-degenerate instead of the usual positive-definite.
3. It seems that we always choose t(\tau)=\tau (Galilean) and x^{0}(\tau)=c\tau (Minkowskian) but I'm not sure how these choices are justified.
You have to be a little careful with the notation and logic. The tau you wrote in the Galilean case is some universal time function that every observer can measure with a good clock (up to affine re-parametrizations for origin and units). The tau you wrote in the Minkowski case is the proper time as measured by a clock carried by that specific observer. There is a major difference in logic there.
Otherwise, I don't see any problem with what you've written down.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
