Transmission Lines: Frequency Limitations & Attenuation
Landline frequency limitations are primarily influenced by factors such as attenuation, which varies with frequency and material, and impedance mismatches that cause reflections. Copper wires experience skin effect losses and dielectric losses at high frequencies, limiting effective bandwidth. While theoretically higher frequencies could be used, practical constraints like equipment capabilities, cost, and crosstalk between lines significantly restrict data transmission speeds. Additionally, multiplexing techniques are employed to maximize subscriber capacity on fiber optic cables, typically capping individual bandwidth to around 300-3300 Hz. Ultimately, the maximum capacity of a landline connection is determined by noise, interference, and the ability to distinguish digital signals.
quantumlight
I am writing my senior thesis on communication networks and this question sort of popped into my head:
What determines what frequencies you can use in a landline connection? (e.g. say I have a wire connecting point A to B to send a bunch of signals, what prevents me from using the entire bandwidth from 1 hz to 1 ghz and beyond?)
In wireless networks I guess some frequencies have lower attenuation over long distances than others due to the composition of atmosphere or objects in between points A & B that absorb. different frequencies. Also you don't want two people to have their cellphones use the exact same carrier in the same zone or you won't be able to separate it out at the receiver.
However how do these limitations apply if you have a landline, you couldn't possibly be interfering with other landlines...? and how does the attenuation vary depending on whether the wire is copper, zinc etc. on frequency?
If I don't care about equipment complexity, what limits me from using my phone line to transmit at ridiculous data speeds for everything from internet to voice because I can use all the bandwidth possible?
Thanks
Landlines have both velocity dispersion and frequency-dependent attenuation. The attenuation arises from both skin effect losses (√f) in copper and 1/f dielectric losses (at very high frequencies). Impedance mismatches cause reflections, which depend on phase advance between reflection points. Twisted pair lines try to decouple wire pairs in trunk lines. Some lines are full duplex (simultaneous bi-directional transmission). Time division multiplexing uses shared lines.
Look up quarter wave impedance transformer for example of reflections at http://en.wikipedia.org/wiki/Quarter-wave_impedance_transformer
In most places the signals from individual subscribers is multiplexed onto fiberoptic cable. In order to get as many subscribers on one fiberoptic cable as possible, the bandwidth of each subscriber is limited, usually to 300 - 3300 Hz. It is possible to get higher bandwidth channels at a higher price.
http://computer.howstuffworks.com/question372.htm
The attenuation of coax tx lines get quite high when frequency goes up into GHz range.
New modulation scheme can make many signals of same modulation frequency possible. Modulation like OFDM make possible use receivers that only work if you have the right key. BTW, this is invented by a beautiful actress called Hedi Lamar in WWII
I don't think the material is going to make a big difference if it is copper, gold, silver type of good conductor. Some maybe, the conductivity is not that big a difference between the ones I gave, it is not like 100% better or what!
Thanks
Some phone lines are not gear for high speed, but slowly they are upgrading them. Theoretically, you can get much higher frequency.
This is a seriously practical-based topic, involving COST as much as anything else - plus History (Much of our traffic can be expected to be going through at least one link of old equipment).
You assume that there is no crosstalk on landlines. A massive assumption. Where there are bundles of twisted pairs, they 'talk' to each other. There are clever systems for swapping connections every so often, in order to help cancel the effects of crosstalk. But it's always a matter of cramming as much as possible into the available pipe space.
There is another way to improve performance and that is to take longer and longer to process the signals. That introduces a delay which is an extra 'cost'.
Your 'bottom line' question about maximum possible capacity has not definite answer but is basically comes down to noise, interference, inter-symbol interference and the effect on 'eye height' (ability to distinguish between digital states).
Hedi Lamar. Gorgeous actress - reputed to be the first to do a nude scene on a general release film. COR!
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
