Efficiently Solve PDE Systems: Expert Tips and Solutions | Help Needed
L0r3n20
Hi all! I'm stuck with a system of PDE. I'm not sure I want to write it here in full, so l'll write just one of them. I've found a solution to this equation but I'm not sure it's the most general one since when I plug this solution into the other eqs, I get a trivility condition for the coefficients
2\bar{k}^1\left(\bar{s},\bar{t},\bar{u}\right)-2 k^1\left(s,t,u\right)+\left(s-\bar{s}\right)\left(\partial_s k^1\left(s,t,u\right) + \bar{\partial}_{\bar{s}}\bar{k}^1\left(\bar{s}, \bar{t}, \bar{u}\right)\right) =0
Can someone help?
Not sure I've understood the equation. Is this simplification valid:
2u(x) - 2v(y) + (y-x)(∂v/∂y + ∂u/∂x) = 0
If so:
∂v/∂y + ∂u/∂x = 2(u-v)/(x-y)
Consider (u, v+v') is also a solution. So
∂v'/∂y = 2v'/(y-x)
v' = (y-x)2f(x)
where f is an arbitrary function of x.
Does that help?
Thank you for the answer. Ok that was useful, at least a bit. In fact, although it is correct, I need a u and a v depending ONLY from one of the two variables (x and y). In fact I'm dealing with (anti)holomorphic functions and I need them to respect the holomorphicity condition.
OK, so make f(x) constant. You can do likewise for (u+u', v).
Even thought I set f(x) constant I get the x-dependence from y-x, right?
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
