Is this how a dipole antenna works?
A dipole antenna operates by creating oscillating electric and magnetic fields that combine to form electromagnetic waves. The movement of charges within the antenna generates these fields, which can radiate energy into space. Resonance occurs when reflected waves from the antenna's ends combine with incoming waves, creating a standing wave that enhances power radiation at specific frequencies. Understanding this process requires familiarity with Maxwell's equations and the interaction between near and far fields. Continued study and experimentation are recommended to deepen comprehension of antenna theory and its complexities.
CraigH
I'm currently writing a report on antennas and I am really struggling to understand the theory.
Here's what I've got so far;
Basics:
.A moving charge causes a magnetic field
.If the direction of movement is reversed, so is the direction of the magnetic field
.A non moving charge has no magnetic field. (if it is not moving relative to the observer)
.Therefore a charge accelerating and decelerating causes a changing magnetic field
.A charge oscillating sinusoidally causes a sinusoidal magnetic field
.The charge also has a electric field surrounding it
.The electric field does not change everywhere at the same time as the field cannot travel faster than the speed of light
.The electric field is mirrored in the ground plate of the antenna creating a dipole
.This dipole has an opposite electric field which is in phase with the original electric field
.The resultant electric field surrounding the charge is an oscillating electric field
.The electric field is perpendicular and in phase with the magnetic field.
.This is an EM wave
Resonance:
.The current traveling through the antenna can also be described as a wave
.This wave is reflected from the end of the antenna
.Wave theory tells us that the reflected wave will be inverted
.This reflected wave will superpose itself with oncoming waves
.At certain frequencies the result of these reflections will cause a standing wave
.There will only be a standing wave at these frequencies
.The value of these "resonant frequencies" is dependent on the dimensions of the antenna, just like the resonant frequency of a string depends on the length of the string
.The standing wave has a much larger amplitude than a traveling wave, so at resonance more power can be radiated
Is this correct? If not can someone please tell me where I am going wrong.
I've been reading around this subject for about a month now, and this is the best I can come up with so if someone could finally put this subject to rest for me that would be amazing.
Thanks.
Here's what I've got so far;Basics:
.This is an EM wave
Resonance:
.The standing wave has a much larger amplitude than a traveling wave, so at resonance more power can be radiatedIs this correct? If not can someone please tell me where I am going wrong.
Thanks.
It is mostly correct, but with a few typos/errors. Do you have access to Stutzman & Thiele?
https://www.amazon.com/dp/0471025909/?tag=pfamazon01-20
With respect to the resonance and radiation, you really need to include Maxwell's equations.
imagine you're holding a sizable negative charge and i am holding a sizable positive charge. and imagine we are standing a few meters away from each other and facing each other and restricting the movement of our charges to move only up/down and left/right, perpendicular to the line that connects us.
now the charges attract each other so if i move my charge up, your charge follows it up. then i move it down, and your charge follows it down. i move it to my left (your right) and your charge follows it right, and i move it to my right (your left) and your charge follows it left.
if i move my charge up and down several times, your charge also moves up and down the same number of times. that's an electromagnetic wave. if i move my charge up and down a million times a second, you can tune that in on the AM radio. if it's 100 million times per second, you can tune it in on an FM radio. if it's 500 trillion times per second, you will see it as a blur of orange light.
my charge that i am holding and pushing around is, essentially, a transmitting antenna and your charge that you are allowing to be pushed around by the prevailing electromagnetic fields is, essentially, a receiving antenna.
in a simple 1/2 wavelength straight-line dipole, in the transmitting antenna, charge is being forced (by the transmitter electronics) to slosh around back and forth in the metal dipole element. that emits an EM wave. in the receiving antenna, that wave causes the free charge in the conductive dipole element to slosh back and forth, which is detected by the receiver electronics.
that's about as basic as i can think of regarding how a simple antenna works.
.This is an EM wave
Thanks.
That's not bad for a whole month on a very complex subject. A simple wire with a few bends can't be that hard. :devil:
I think a point that should be made is that an antenna is the interface of two 'causes' of EM fields. The EM fields that are generated by the moving charges or currents (near field) in wires are localized near the charges/currents so they stay close to the antenna and store the power to be radiated. The varying field lines from the moving charges/currents around the antenna extend into space (they carry energy) and as they move they create it's own self-sustaining EM field that's not from moving charge/current but from a changing E or B field and travel into (far field) space as EM radiation. How this happens might be beyond the scope of your report but the book recommended by Berkeman will help to understand the process.
I would say that your understanding of how a dipole antenna works is generally correct. A dipole antenna works by creating a changing electric field and a changing magnetic field, which combine to form an electromagnetic wave that can be transmitted or received. The oscillating electric field is created by the movement of charges in the antenna, while the magnetic field is created by the changing electric field. This combination of fields forms an electromagnetic wave that can travel through space.
Your explanation of resonance is also correct. At certain frequencies, the reflected waves from the end of the antenna will combine with the incoming waves to form a standing wave. This standing wave has a larger amplitude, allowing for more power to be radiated at those specific frequencies.
However, it is important to note that the theory behind antennas can be quite complex and there are many different types of antennas, each with their own unique properties and behaviors. It is also important to consider the effects of the surrounding environment and how they can impact the performance of an antenna.
If you are struggling to understand the theory behind antennas, I would recommend seeking out additional resources or consulting with a knowledgeable expert in the field. It may also be helpful to conduct experiments or simulations to further your understanding. With persistence and continued learning, you will be able to fully grasp the concepts and principles behind antennas.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
