Two wire touching side by side
  • Thread starter Thread starter Askara
    Wire
When nichrome wire coils touch each other, the risk of a short circuit depends on several factors, including the contact area and the overall setup. The small contact area between the wires can result in high resistance, potentially preventing a short circuit. However, if the contact is sufficient, it may still lead to a short, similar to how banana plugs can achieve low resistance despite minimal contact. The specific conditions of the wires, such as surface quality and pressure, play a crucial role in determining the outcome. Ultimately, careful consideration of these factors is essential to avoid electrical issues.
Askara
so say i have a nichrom wire of 0.5 mm dia, and pass 230 v through it.and i coil it up, but some part of the coil touched (imagine the wire parallel to each other so basically 2 circle.) will it short the circuit? i have been told that the area they touch is extremely smaller since they are circular, so the resistance is very high compare to going through the wire normally, hence it doesn't short?
It depends on your setup, the surface of the wires and some other things. As an example: if you contact two banana plugs, you can get a resistance below 0.1 Ohm, and their contact area is basically point-like.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
