Simple laser using magnifying glasses, lenses and a laser pointer
Building a simple laser with magnifying glasses, lenses, and a laser pointer is possible, but using a standard laser pointer may not achieve the desired heating effect. Legal laser pointers are designed with low power outputs to prevent injury, limiting their ability to create heat. For effective heating or cutting, a higher power laser is necessary, along with a thorough understanding of safety protocols. Engaging in potentially dangerous activities without proper guidance is discouraged. Prioritize safety and consider the implications of using higher power lasers.
Aidan39
Hi guys, sorry new to this, I'm looking to build a simple laser using magnifying glasses, lenses and a laser pointer. How would I go about it and can I get away with using the pointer or do I need a laser diode?
A laser pointer IS a laser. So it is not clear what you are you trying to build. Could you be more specific.
(I assume you are not going to use the pointer as a pump-laser)
Sorry for being unspecific, I'm trying to make a low power laser capable of creating heat on an object not just light
The reason that legal laser pointers have low power output is so they can't "create heat" and cause injury to people.
If you want to use a laser for heating or cutting, you need a higher power laser, and YOU ALSO NEED TO UNDERSTAND THE SAFETY REQUIREMENTS OF WHAT YOU ARE DOING. This forum won't give you any advice on potentially dangerous activities, except for "don't do it".
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
