Boiling Water Faster in Increments?
  • Thread starter Thread starter Ram012593
    Boiling Water
Introducing water in small increments to a pot does not boil 5 gallons faster than adding it all at once. Heating a smaller volume first can lead to energy loss as steam escapes, while the pot radiates heat more efficiently at higher temperatures. The total energy required to boil the entire volume remains the same, so heating all at once minimizes heat loss. A controlled experiment could provide definitive results, but the initial theory suggests that adding all the water simultaneously is more efficient. Conducting such an experiment is planned for the future.
Ram012593
If I have a 1.5 kilowatt range can I get 5 gallons of water boiling faster by introducing it to the pot in small increments and waiting for the water that's already in the pot to start boiling before introducing the next increment or would it be the same amount of time if I just dumped the whole volume in at once? Thanks much in advanced and if I put this in the wrong section I apologize but it seemed like it would be general physics to me.
I don't think so. In fact, I think it could take longer if you don't add the extra water before it starts boiling and if you think about "Newton's law of cooling" (where heat dissipation is proportional to the temperature difference) .
5 gallons of water take a certain amount of joules to boil. If you heat 1 gallon to boil you have added 1/5 of the energy needed. But if it continues to boil, then that extra energy is lost to the environment by water boiling away. Also, your pot is at a hotter temperature relative to the environment so its going to radiate heat away faster. The better thing to do is to heat the whole 5 gallons at once. That way you will lose less heat to the environment via boiling and your water will be spend more time at a temperature closer to ambient and will thus radiate away less heat.
Does that makes sense? I think it does, but its just my first thoughts.
Likes 1 person
Thank you that is what I thought as well but my friend was arguing otherwise.
Have you tried doing an experiment to compare the two scenarios?
Not yet. When get the necessary resources to perform a controlled experiment I plan to.
Let us know how you set it up and what the results are!
Will do though it may not be for a while.
