Understanding ∏ and other mathematical constants
π is a single mathematical constant defined as the ratio of a circle's circumference to its diameter, resulting in an infinite decimal representation. Its significance arises from its fundamental relationship to circles, which appears in various mathematical equations and natural phenomena. While some argue that π is no more special than other constants like e, its unique properties and applications in geometry and trigonometry make it particularly relevant. The discussions emphasize that any use of π is derived from its definition related to circles, highlighting its pervasive presence in mathematics and nature. Understanding π requires recognizing its foundational role in geometry and its connections to other mathematical concepts.
Niaboc67
What exactly is ∏? I've never quite understood why it is apparent in so many different equations and formulas. Why is it there? Why is it apparent in nature so much? And ∏ it's just a infinite set of numbers why is it any more relevant than any other set of infinite numbers. Why is 3.14... so important to the fundamental properties of this universe. The same goes with e and ψ and Ω and every other set of numbers. Are all constants just sets of infinitely repeating numbers that are set into different sequences?
I am in need of some demystification. Thank you!
Mathematics news on Phys.org
First, \pi is NOT an "infinite set of numbers". It is a single number that happens, like almost all real numbers, to have an infinite number of digits in base 10 notation. And I don't see anything special about "\pi". It doesn't seem, to me, to be any more important than "e" and considerably less important than "0" or "1"!
I still do see why ∏ possesses this quality. What makes it any different from using other numbers? why is this set of numbers used as opposed to any other set of numbers, or single number as referred to? 3.14159265359, does it just so happened to be that number you get for the ratio of any circles circumference to it's diameter? so anytime we are referring to ∏ automatically it is in some relation with circles?
Again, ##\pi## is a single number, not a set of numbers.
Yes, ##\pi## is defined as the ratio of a circle's circumference to its diameter. If you take an arbitrary circle and calculate that ratio, you will get ##\pi## (more or less exactly depending on your accuracy of measurement).
Any other use of ##\pi## must somehow have been derived from this definition. So everywhere you use ##\pi##, there must have been some relation to circles, although this relation is sometimes very difficult to discover.
Niaboc,The link I gave includes everything you want. Please read it. I suggest you to read the entire article.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
