Word/notation for "swallowing constant"?
  • Thread starter Thread starter HJ Farnsworth
    Constant
The discussion revolves around the concept of absorbing constants into a single variable during mathematical derivations, as observed in an astrophysics course. The term "swallowing constant" is proposed, but participants note that there is no widely recognized name for this practice. It is suggested that simply referring to it as "absorbed into k" is sufficient, as the constant itself does not hold any special significance. The conversation highlights the lack of formal notation or terminology for this concept in mathematical literature. Overall, the focus is on the simplification of expressions by consolidating constants.
HJ Farnsworth
Greetings,
I used to sit in on an astrophysics course, where during derivations the professor would often absorb all of the constants in a given expression into a single ever-changing constant at the front of the expression. E.g., for a trivial example, let X be 3 times the circumference of a circle of radius r times the perimeter of a square of side length l, with k the constant in front:
X=kC(r)P(l)=krP(l)=krl.
The constant 3, the 2\pi from C(r), and the 4 from P(l) are all absorbed into k.
Is there a common name for this kind of device, which in the title of this thread I just called a "swallowing constant"? Also, is there a common notation for it?
Thanks for any help that you can give.
-HJ Farnsworth
Mathematics news on Phys.org
I would use the phrase you did: "absorbed into k". There is no special name for the constant into which other constants because there is nothing special about it.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
