Cancelling Squares: Can It Be Done?
  • Thread starter Thread starter PhYsIcAlLy QuAnTuM
    Cancelling Squares
Cancelling squares in equations like (a-b)² = (c-b)² is debated, as taking the square root can lead to incorrect conclusions. While one might simplify to (a-b) = (c-b), this ignores the possibility that (a-b) could equal -(c-b). The correct interpretation is that if (a-b)² = (c-b)², then either a-b = c-b or a-b = -(c-b). Therefore, the assertion that squares can be cancelled without considering both scenarios is misleading. Understanding this distinction is crucial for accurate mathematical reasoning.
PhYsIcAlLy QuAnTuM
Greetings friends,
I have come across an argument on cancelling the squares on either side of an equation. For example if the equation is (a-b)^2=(c-b)^2 my argument is that i can cancel the squares by taking the square root of both sides as to get (a-b)=(c-b) and hence a=c. But others says that squares cannot be remove as such. So I thought i would consult you guys. What do you think, am i wrong or are they wrong?
thanx for your help!
Mathematics news on Phys.org
A^2=B^2 then that tells us that A^2-B^2 = 0, or that (A-B)(A+B) = 0, and so we have that either A=B, or A=-B.
This is rather evident since, consider that (-2)^2=2^2.
In other words, if (a-b)^2= (c-d)^2 then EITHER a-b= c-d OR a-b= d-c.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
