Black Holes & Infinity(Singularities)
  • Thread starter Thread starter spacecadet11
    Black holes Holes
Matter approaching a black hole does not reach the speed of light when crossing the event horizon; instead, it continues toward the center at a finite velocity. The escape velocity at the event horizon is defined as the speed of light, and once inside, escape velocity becomes meaningless as all paths lead to the singularity. A singularity represents a breakdown in mathematical models, indicating that current equations cannot accurately describe conditions at that point. Infinity arises in these models as a mathematical artifact, similar to how certain formulas become undefined under specific conditions. Understanding these concepts is crucial for grasping the nature of black holes and singularities.
spacecadet11
Hello. I would like to know. Does matter when heading towards a black hole then crossing the
event horizon threshold reach the speed of light? I am guessing no. It simply crosses the threshold
and at a finite velocity heads toward the center of the black hole.
The escape velocity of a black hole I believe is something greater than the speed of light. Has anyone actually calculated what that number is?
What is a Singularity? I only believe that matter simply reaches the center of a black hole.
Where in the world does infinity come from?
Thanks for any and all responses
Bye
SC
Astronomy news on Phys.org
I'm not sure on this one, but I think you have it right.
Why do you think it is greater than c? I've never heard that before. The event horizon is DEFINED as being the place where the escape velocity is c.
Singularity: a place where our math models give results that can't possibly be real, so we say that the model has broken down. We we abbreviate the aforgoing sentence by just saying "singularity"
No. Nothing with any mass can ever reach the speed of light; it can only approach it and suffer mass gain and shortening.
Reaches the speed of light relative to what? As far as the falling object is concerned, it's at rest while the black hole is moving towards it (have you ever tried skydiving and experienced the Earth "rushing towards you"?). A distant observer will find that the speed of the falling object relative to the observer approaches ##c## as the object disappears into the black hole. If the infalling object emits a flash of light in any direction at any time during its fall, the flash of light will move away from the object at ##c##.
There's no meaningful definition of escape velocity once inside the event horizon. No matter what direction you move, no matter how far and fast you move in that direction, your path will lead to the central singularity. Although...
The infinity is just an artifact of the math. For a more intuitive example, we could consider the classical formula for the force between a positive-charged and a negative-charged particle: ##F=kQ_1Q_2/r^2##. It works just fine as long as ##r##, the distance between the two particles, is not zero, but blows up to infinity if ##r## is zero. That's a singularity, but all it really tells us that you can't separate two charged particles by zero distance. A similar singularity appears if we set ##r=0## in the Schwarzschild equation that describes a black hole, and again it just tells us that that's not the right formula to use there.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
