How is this proof valid? ax(bxc) = (c.a)b-(b.a)c
  • Thread starter Thread starter mr_coffee
    Proof
The discussion centers on the validity of a proof for the vector triple product, specifically the equation ax(bxc) = (c.a)b - (b.a)c. The user initially struggles with a mismatch in terms during the proof's final part, questioning the correctness of their notation and vector representation. They highlight a specific discrepancy between terms in the two expressions. Ultimately, the user resolves the issue after a friend points out that a term was missing in the ax(bxc) calculation. The conversation emphasizes the importance of careful notation and term inclusion in vector proofs.
mr_coffee
Hello everyone, I'm looking at this proof and its making sense until the very last part, and it doens't friggin' work...the terms don't match up... Also is the notation I used correct in the proof, like does there have to be any vector notation I don't have or do you see anyhting you don't like? I'm proving the "The Vector triple product"
Here is my proof:
http://img89.imageshack.us/img89/9758/rpooof6rk.jpg
Look at the 2nd part of ax(bxc) -----> a1b1c3 - a2b22c3 + a2b3c2
then look at the last part (c.ad)b - (b.a)c ---> a1b3c1 - a1b1c3 + a2b3c2 - a2b2c3
You see only 1 term isn't match up! the a1b1c3 not equal to a1b3c1 what's going on? Thanks
Nevermind, my friend found the problem! I forgot a term in ax(bxc) part.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
16K
