A 50 cubic foot tank contains saturated 134a at 100F and a quality of 50%
The discussion revolves around calculating thermodynamic properties of saturated R-134a in a 50 cubic foot tank at 100°F with a quality of 50%. Participants seek clarification on specific calculations related to initial internal energy, mass, average enthalpy, final quality, and mass withdrawn. Confusion arises regarding the formulas used for quality and enthalpy, particularly the roles of specific volumes for saturated liquid and vapor. It is emphasized that the initial internal energy cannot directly determine the final quality due to mass leaving the tank, and participants debate the correct approach for calculating average enthalpy. The conversation highlights the complexities of thermodynamic calculations and the need for precise understanding of the underlying principles.
joejoe121
A tank of 50 cubic feet contains saturated 134a at 100 F and a quality of 50%. Vapor is withdrawn from the top of the tank until the temperature is 50 F. The process is adiabatic.
u = u_f + x(u_g-u_f)
v= = v_f +x(v_g-v_f)
x = (u - u_f)/(u_g-u_f)
h_avg = ((h_g)_100F _ (h_g)_50F)/2
mass_tank = volume/specific volume_final
mass_tank_final = 50 cubic feet / specific volume_final
mass_vapor = mass_tank - mass_final
I've attached all my work and data table I used to answer the questions but there isn't an answer key so I would like a second opinion.
a) The initial specific internal energy is.......Btu/lbm
b) The initial mass is....lbm
c)The average enthalpy of the withdrawn vapor is.....Btu/lbm
d)The final quality in the tank........%
e)The mass of 134 that is withdrawn is......lbm
What are you asked to determine?
I'm so sorry i forgot to post the questions. I'll edit it.
I don't follow what you did in parts (d) and (e). Can you please explain?
in D, i used the formula to find quality using internal energy values and in E I'm wanting to find mass, so I use the volume of the tank divided by the specific volume of the tank at 50 F which I used the same quality formula after I found the quality.
I don't follow. My approach would be to let ##x_f## be the final quality in the tank and ##m_f## be the final mass in the tank. Then $$U_f-U_i=m_fu_f-m_iu_i=-(m_i-m_f)\bar{h}$$and$$v_{Lf}+(v_{Vf}-v_{Lf})x_f=\frac{V}{m_f}$$where ##\bar{h}## was the average specific enthalpy of the vapor exiting the tank.
I'm confused about the $$v_{Lf}$$ and $$v_{Vf}$$
The final specific volumes of the saturated liquid and vapor.
for your first formula you posted. What do I equate -(m_i-m_f)h_{avg} to?
And did i solve for my average enthalpy correctly?
Is it correct to say that the initial internal energy can be used to find the final quality?
No, because mass has left the tank with enthalpy ##\bar{h}##.
Is what I did in part C correct or should I say the average enthalpy of the withdrawn vapor just be the saturated vapor value at 100 F?
And I'm really confused on finding quality at this point.
