A 50cm wavelength EM wave in air has 50mW/m^2 of energy.
The discussion revolves around calculating properties of a 50cm wavelength electromagnetic wave in air, specifically its frequency, average electric field, magnetic field strength, and wavelength in water. The frequency is determined to be approximately 17.3 kHz. The average electric field is calculated using the formula E = √(50/.5*ε°*c), although there is uncertainty about its correctness. To find the wavelength in water, the index of refraction must be applied. The conversation emphasizes the need for accurate calculations and the relevance of material properties in wave behavior.
Physics8o8
what is the frequency?
what is the average E field?
What is the B field strength?
What would be the λ in water?
I found the λ. How do I find it in water
E = √50/.5*ε°*c... is that correct?
frequency = 17.3 Khz
You will have to use the index of refraction for water.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
