Proof of Infinite Cyclic Group Isomorphism to Z
  • Context: Graduate
  • Thread starter Thread starter radou
    Cyclic Group Proof
The discussion revolves around the proof that every infinite cyclic group is isomorphic to the additive group Z. Participants explore the necessary conditions for a mapping to be an isomorphism, particularly focusing on the kernel of the mapping and the implications of the group being infinite.
  • One participant presents the mapping f : Z --> G defined by k |--> a^k and questions how to show that the kernel is trivial.
  • Another suggests using the fact that the group is infinite to argue about the kernel.
  • Some participants discuss the implications of the kernel containing a least positive integer m such that a^m = e, and how this leads to contradictions regarding the group's infinite nature.
  • There is a claim that if a^k = e for k ≠ 0, it implies the group is finite, which is contested by others.
  • One participant asserts that the isomorphism is trivial and relates it to taking logarithms base x.
  • Another participant discusses proving that an infinite group is cyclic if and only if it is isomorphic to each of its proper subgroups, raising concerns about the logic in their reasoning.
  • There are discussions about the nature of subgroups of cyclic groups and the implications of isomorphisms on the cardinality of groups.
Participants express differing views on the details of the proof, particularly regarding the kernel of the mapping and the implications of the group's infinite nature. There is no consensus on the most straightforward approach to the proof, and some participants challenge each other's reasoning.
Some participants reference theorems and properties of cyclic groups without providing detailed proofs, leading to assumptions that may not be universally accepted within the discussion. The exploration of injectivity and the nature of isomorphisms introduces additional layers of complexity that remain unresolved.
  • #31
So, if I take ab, <ab> = {(ab)^p : p e Z} = {a^p*b^p : p e Z}, since G is abelian. For p = mn, (ab)^mn = e. But I'm not sure if this shows anything, since if the order q of an element c is known, then c^q = e.
  • #32
What? You know that (ab)^mn=e, so you know that the order of ab divides mn (eg lcm(m,n) is such a number...)
  • #33
I get it, I should have had the proposition which states that fact in mind. Thanks.
  • #34
Another question which confuses me.
Let H, K, N be subgroups of G such that H < K, H\cap N = K\cap N and HN = KN. Prove that H = K.
Well, the H\cap N = K\cap N part confuses ne, since, by definition,
H\cap N = \left\{x \in G : x \in H \wedge x \in N\right\}, and K\cap N = \left\{x \in G : x \in K \wedge x \in N\right\}. Since H is a subgroup of K, it is also a subset of K, and hence H \cap N must be a subset of K \cap N. Since they're equal, there doesn't exist an x from K which isn't in H, and hence H = K.
There is probably something terribly wrong with my reasoning, but unfortunately, I can't figure out what it is. Thanks in advance.
  • #35
Since, at no point, did you invoke the fact that HN=KN, you might want to rethink what that means.
  • #36
radou said:
hence H \cap N must be a subset of H \cap N.
I presume you didn't mean to write that.
  • #37
What are |HK| and |HN|?
  • #38
A typo - I corrected it.
If HN = KN, we know HN\subseteq KN, which is quite obvious, since H < K, and we know KN\subseteq HN, so x = kn e KN implies x e HN, so every k must be from H, and hence K\subseteq H, which implies K = H. But why are two facts given in the problem (HK = KN and the first one about intersections), since they lead to the same conclusion? Again, obviously my reasoning is wrong.
  • #39
Why did you ignore my reply? I'll say it again: What are |HK| and |HN|?
And your reasoning failed because kn being in HN doesn't imply k must be in H. kn in HN means there exists an h in H and an n' in N such that kn = hn', so k = hn'n-1, which doesn't necessarily lie in H.
  • #40
Thanks, I got it now.
Did you mean: "What are |HN| and |KN|?" Since then, |HN| = |H||N|/(H\capN) and |KN| = |K||N|/(K\capN), and, since HN = KN, and since H\capN = K\capN holds, it follows that |H| = |K|, and since H < K, we have H = K.
Edit: although, the theorem about the cardinality of HK applies only for finite subgroups, at least that's what my book says, and the problem doesn't mention they're finite. :biggrin:
  • #41
Whoops, yes that's what I meant! And yeah, I seem to have also missed that they aren't necessarily finite.
Anyway, let k be in K. Then if kn1 is in KN=HN, there exists an h in H and an n2 in N such that kn1 = hn2. We can re-write this as h-1k = n2n1-1. The left side is in N, and the right side is in K, because H <= K. Thus h-1k is in K\capN = H\capN.
Can you take it from here?
  • #42
If h^{-1} k is in H\capN, I assume it doesn't need to be true that h^-1 and k are in H\capN, too? If so, then I don't think I have any bright ideas. (I have to show that k is in H, right? It's the only inclusion we need, since H < K implies H is a subset of K.)
  • #43
How is H\capN related to H?
  • #44
It is a subgroup of H.
  • #45
Right. h-1k is in a subgroup of H (and therefore in H). So...
  • #46
...so h^{-1}k = h&#039;, for some h' in H\capN. After multiplying with h from the left, we have k = hh' , and hence k is in H, which proves the point. (I hope..)
  • #47
Yup.(message too short)
  • #48
morphism said:
Yup.
(message too short)
Thanks a lot!
  • #49
The problem states that f : G --> H is a group homomorphism, H is abelian, and N < G, whith Ker(f) contained in N. One has to prove that N is normal in G.
The first thing that crossed my mind was a neat corrolary which stated that there is a bijective correspondence between the set of all subgroups of G containing Ker(f) and all subgroups of H, such that normal subgroups correspond to normal ones. In that case, the proof would be almost trivial, but then I remembered that the corollary required f to be an epimorphism. :rolleyes:
Well, I know that, since H is abelian, every subgroup of H is abelian, and I know that Ker(f) < N < G, but I can't come up with anything constructive. So, any pushes in the right direction are welcome.
  • #50
Any map is surjective onto its image.
  • #51
So if I look at the epimorphism f : G --> Im(f), I could apply the corollary? eg, since Im(f) and every other subgroup of H is normal, there must exist a normal subgroup of H to which N is mapped?
  • #52
Forget H. Replace H with Im(f).
  • #53
OK, so f : G --> Im(f) is an epimorphism. Since there exists a bijection between the set of all subgroups of G which contain Ker(f) and the set of all subgroups of Im(f) (where normal subgroups correspond to normal ones), the group N < G is mapped to some subgroup K < Im(f). Since K is normal (because it is a subgroup of an abelian group), N must be normal in G.
  • #54
can some body help me in solving the following problem.
a finite group with an even number of elements contains an even number of elements x such that x^-1 = x.
  • · Replies 41 ·
10K
  • · Replies 26 ·
