The inverse function to recover the function from the gradient operation e.g. ## \nabla F ## is ## F=\int \nabla F \cdot d \vec{s} ## where ## d \vec{s}=dx \hat{i} +dy \hat{j} +dz \hat{k} ##. These are three separate integrals (x,y, and z) that are often easily performed... The ## \nabla \cdot \vec{E} ## has an integral solution. (There also can be homogeneous solutions as well to both this one and the integral solution to the curl that needed to be added to this particular integral solution). In MKS let's assume ## \nabla \cdot \vec{E}(x)=\rho (x) /\epsilon_o ##. (It works for other vector functions as well besides the electric field ## \vec{E} ##). Then ## \vec{E}(\vec{x})=\int [(1/(4 \pi \epsilon_o)) \rho(\vec{x}') (\vec{x}-\vec{x}')/|\vec{x}-\vec{x}'|^3] d^3 \vec{x}' ## (basically the inverse square law for the electric charge distribution ## \rho (\vec{x}) ##)... The integral solution to the curl takes the Biot-Savart form. e.g. For ## \nabla \times \vec{B}(\vec{x})=\mu_o \vec{J}(\vec{x}) ##, the solution of this is the Biot-Savart integral form: ## B(\vec{x})=\int [(1/(4 \pi \mu_o)) \vec{J}(\vec{x}') \times (\vec{x}-\vec{x}')/|\vec{x}-\vec{x}'|^3] d^3 \vec{x}' ##. Oftentimes this curl integral needs a homogeneous solution of ## \nabla \times \vec{B}=0 ## added to it. (I don't think this is usually the case with the B field, but for the H field and in other cases it often requires a homogeneous solution as well) And you ask, are they of any practical use? The answer is yes. The integral solution to the divergence equation is often used in E&M calculations. The Biot-Savart equation is well known, but it doesn't seem to be emphasized so much as the integral solution to the curl equation in the E&M textbooks. For the curl B equation, the integral solution that is more often shown is Ampere's law in integral form (for the steady state case) which comes from Stokes theorem: ## \oint \vec{B} \cdot d \vec{l}=\mu_o I ##.
