A Few Questions I Would Like to Endeavour to Ask
  • Thread starter Thread starter Procrastinate
In preparing for a Physics exam on DC circuits, key points include strategies for handling multiple power sources, where applying Kirchhoff's rules can be beneficial. The voltage symbol in an EMF does not have a standardized representation based on the number of lines; it is not indicative of voltage levels. Additionally, current in a DC circuit conventionally flows from the positive terminal to the negative terminal, while electron flow is in the opposite direction. Understanding these concepts is crucial for effective problem-solving in circuit analysis. Mastery of these principles will enhance exam readiness.
Procrastinate
Ok, I have a Physics exam in two days (on DC circuits) and I've pretty much done everything I've needed to. However, I am anticipating a few difficult problem solving questions, so just in case I would like to clarify a few things:1. Generally, if you had two or more sources of power supply (EMFs) in a circuit; how would you tackle the problem? Just a general formula or tactic would be appropriate?
2. With regard to the voltage symbol in an EMF, does it matter how many lines you have or do a certain amount of lines denote a certain amount of voltage.
3. This last question isn't really to do with problem solving, but rather, I've always wondered. In a DC circuit, does the current always travels from the negative side through a possible route and to the positive end of the power supply?
1) Use Kirchhoff's junction and loop rule.
2)Do you mean the battery (smal -| big |+)? You cannot deduce the voltage over the battery's terminals from any lines/drawing.
3)Current runs, conventionally, from the + terminal to the - terminal. The electron current itself, since electrons have negative charge, runs from the - terminal to the +terminal
