A general transistor switching circuit question
24 replies · 4K views
Planobilly
Hi guys,
I need to design a transistor switching circuit to switch two channels on a tube/valve amp without adding noise or altering the sound of the tube channels. What issues am I likely to have to deal with?
Thanks,
Billy
Audible "Pop" when it switches,
Faint bleed through of wrong channel when the one selected is in a quiet interval.
Best analog switch i know of is Vishay DG611 series
probably somebody more current than i knows of an IC made to do exactly what you want. @analogdesign ?
to get you conversant:
http://www.ti.com/lit/sg/slyb125d/slyb125d.pdf
http://www.vishay.com/docs/49951/49951_sg2134.pdf
http://www.vishay.com/docs/70057/dg611.pdf
http://www.digikey.com/product-detail/en/vishay-siliconix/DG611DJ-E3/DG611DJ-E3-ND/2296848
old jim
Thanks Jim,
The intent is to build the basic amp on a turret board. That does not lend itself to placing typical relays and transistors on the same board. I sort of had in mind to build a PCB that would reside above the turret board to contain at least the transistors.
Also the voltages needed to power the relays and other voltages needed to power the transistors adds complexity to both the power transformer/rectifier design and wiring layout.
I am aware of the "pop" issue.
Thanks for the links, I will look through the links you provided.
Thanks,
Billy
Yes Jim, things change and get more complex by the second. I really feel like a dinosaur at times!..lol
Here is a modern guitar amp schematic that has a sort of typical IC/transistor switching matrix for a three channel tube amp. http://www.thetubestore.com/lib/the...esa Boogie/Mesa-Boogie-Nomad-45-Schematic.pdf
It is on page nine of this schematic. The LM3914 is an IC normally used to switch LEDs but in this case it is the first input device coming from a rotary 4 position switch on the amp and also hooked up through a DIN connection to the foot switch when position 4 is selected on the rotary switch. It then runs through a few transistors and JFET to the relays.
Much more complex than I need as I only need to control two relays in my amp design. I only need to switch from channel one too channel two and switch the effects loop in and out.
As much as I can, I have resisted using solid state anything up until now. Well...things I now want to do require it so I have to learn new stuff.
A old Navy guy, Dave and I have a basic schematic roughed out, with the two preamp channels, reverb tube and driver, inverter and PA. 100 watt amps get big and heavy real quick. We are working on the power supply at the moment leaving the switching for last. We don't have any values for the resistors and caps indicated on the schematic yet so it would not be readable to anyone but Dave and I as we have that info in our heads. I will post it when we get a bit on down the road with the project. Doing the turret board layout is actually harder than drawing the schematic. I have started to rough it out but that will take a while.Fun stuff but a lot of work!
Cheers,
Billy
Symmetrical low-capacitance diode bridges work well at RF so they should work better at AF. What peak-peak voltages and/or currents are you switching. What is the impedance of the switched circuit.
Thanks guys, I been running like crazy. I played with the band tonight and it is around 2am. I will look into the 4066 tomorrow and other ideas you guys mentioned. Thanks for the help.
I don't play out much anymore but looks like I can still get the people up on the dance floor!
Cheers,
Billy
4066 is a handy analog switch , easy to get
that dg611 is precision and way more expensive
learn on the inexpensive one
i was hoping for a switch made for audio that mutes out the 'pops' have fun
Having used the 4066 many times in audio I have never had trouble with pops. I have built and used voting equipment in communications systems which selects the best audio source based on signal to noise ratio. I could never tell when the voter would switch sources.
Good morning Jim,
By what ever means the issue of a "pop" when switching can not be tolerated. This will be even more of an issue because this amp is operated at near max gain and will be used for screaming modern rock music. Not my cup of tea but that is the use. So, switching at max gain is the norm.
The Mesa schematic above has a switching system that works well. I own a Mesa Nomad 45 so I will do some channel switching test at high gain levels with the rotary switch only. I have never tried that so I am not sure what effect other circuits and ICs in the foot switch itself do in relationship to noise suppression.
This may prove to be a significant learning curve for me.
Billy
There you go, Avgsuper has first hand experience. Maybe he'll share his basic approach.
Dont shift DC levels drastically, be judidious where you switch.
Some of those TI audio gizmos can handle signal below negative rail.
Here is the very preliminary concept schematic of the preamp section. The channel switching will be controlled by a relay at K1.
Here is the prelim PA.
I am considering adding a DC heater to the first preamp tube.
There was a time when dual trace oscilloscopes used twin triodes as electronic selection switches. You might consider controlling the HT or grid bias to gate amplifier stages or channels.
A semiconductor such as CD4066 or DG-series will not survive well in situations where signals greater than +/– 5V might occur.
The problem with relays and digital input analogue switches is the click when switching. Diode switches can switch slowly and quietly because you can control the rate that the diode current changes. They can also handle 400V signals without any problem.
Hi Baiuncore,
I assume lots of potential issues in general with tube amp hybrid designs. I see it all the time in modern amps I repair. High voltage tube requirements with what could be considered crude tube circuit design to begin with and combined with sensitive low voltage silicon devices always presents issues to solve. Add in a few drunk guitar players in the mix and repair guys are keep pretty busy.
Tubes in general are pretty tolerant of voltage spikes and variations in component values and voltages. Transistors are certainly not happy living in that environment. Tubes and transistors are certainly not a marriage made in heaven...lol
This is not "rocket science" as the saying goes but it is my sort of first introduction to having to do the design work. And of course I am way in over my head but that is nothing new.
I appreciate the guidance and ideas you guys are providing.
Cheers,
Billy
Thanks Jim,
I have a 1964 Fender Vibroverb with an intermittent issue I need to solve right away so I will be back to this thread a bit later.
Thanks,
Billy
I have found that the only way to avoid a pop is to use a transformer, so that there is no DC component and no capacitor in circuit. Would a simple relay do the switching job - no risk of distortion?
I have worked with valve equipment since the late 1960s and so I know the problems to be expected when mixing valve and semiconductor technology. Have you ever seen a balanced diode switch?
Planobilly; What have you got against the balanced or symmetrical diode bridge for switching signals quietly?
Hi Baluncore,
No, I have not seen or perhaps just not paid any attention to that type of circuit. All my experience has been in repairing valve guitar amps. I have only recently started trying to design them.
I have built several new amps off existing schematics and played around with various modifications to those amps. Now I am in the process of building one of my own design. The new amp will display the characteristic of both the classic Fender clean sound of the 1960s and the screaming metal tones of the modern rock era. I guess most new valve guitar amps are class AB push pull and mine is also.
Obviously there are still NOS valves to be had, but anyone serious about building more than one or two amps is going to use current production valves. I use JJ valves because I have a direct hook up with the factory and routinely get power valves matched within 1 ma. I use Sovtek sometime for certain rectifier valves and Electro Harmonics in certain cases but they are all current production valves.
I don't have any real like or dislike for valves or transistors. For me it is a question of proper function/cost and end results of the sound it produces. Most new amp designs I see are overly complex and the complexity is of little value to the guitar player.
Cheers,
Billy
