A Lesson on Lorentz Contraction
Lorentz contraction is a fundamental concept in Special Relativity, describing how an object's length contracts along the direction of motion as its speed approaches the speed of light (c). The discussion emphasizes the need for a clear understanding of the associated equations and the significance of c in these equations. Suggested resources include HyperPhysics and school library encyclopedias that cover relativity and its applications, such as the Twin Paradox. The conversation highlights the importance of starting with simpler explanations before delving into more complex theories. Overall, a structured approach to learning about Lorentz contraction can facilitate a better grasp of its principles and applications.
Tido611
ok so i have been assinged to do a 10-12 page written lesson on the lorentz contraction, the thing is that i know very very little about it(we will assume i know nothing about it) so what i was wondering if anybody around here knew anything about it and wouldn't mind offering a hand. If there are certain topics that i should cover within it like the development, uses or stuff along those line. I've searched other places but the explanation they give me is too complex for me to understand right off the bat, so if there are any ideas right off the bat to push me in the right direction it would be great.
come on i know if i post this under a different subject i would actually getting response. Does anyone know anything about Lorentz Contraction? If not would it be possible for me to post this under a different subject, maybe one that gets more rotation?
So what do you know so far about Lorentz contraction? What is the equation for length versus velocity? Why is c so special in the equation? What overall theory is Lorentz contraction considered an integral part of?
To help you, we need to see what you know so far, and what your sources of information are. Like, what grade are you in in school? What textbooks do you have available? You said that your initial research only turned up explanations that were too complicated, but honestly, Lorentz contraction is pretty straightforward, and doesn't even involve calculus at the simpler levels of explanation.
I went to HowStuffWorks.com and did a search on Lorentz, which gave me the link below into the HyperPhysics.com website. In the box with the Lorentz Transformation equations, click on "Relativity Concepts" at the right, and then browse down through the info tree (left side first) some to see if that helps.
http://hyperphysics.phy-astr.gsu.edu/HBASE/relativ/ltrans.html
I know very little about it, i know that it effects both time and length, i know the equations for both of those, i have no idea why c is soo important and i have no idea about the integral part either.
i am in grade 12 and the only textbook i have available is Nelson's grade 12 physics and it doesn't tell me much about the contraction, all the book says is the equation and how to use it.
hyper physics didnt tell me much
Okay, try looking in the technical encyclopedia in your school library under Relativity or Special Relativity. Lorentz contraction is one of the key concepts in Special Relativity. The encyclopedia should have an intro section on Albert and the motivations for SR, and then it should explain the LC in the context of SR. Look also for things like the Twin Paradox, etc., as examples of application of the LC. That should get you started. Then you can use keywords from the encyclopedia and its bibliography to help you find other sources of info.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
