A Modular Arithmetic Proof Problem
  • Thread starter Thread starter e(ho0n3
    Arithmetic Proof
e(ho0n3
Let a, b, s, t be integers with s, t > 0. What conditions must s, t satisfy if the following statement is true:
If a = b (mod s) and a = b (mod t), then a = b (mod st).
The attempt at a solution
If s | a, s | b, t | a and t | b, then st | a and st | b if and only if s, t are relatively prime. This is as far as I've gone. How should I continue?
The statement is equivalent to s | (b-a) and t | (b-a) -> st | (b-a).
Oh, that's right! I completely forgot about that. And by using what I have, I can conclude that s and t must be relatively prime.
Thanks again.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
