Solve Momentum Problem: Boat's Final Velocity
  • Thread starter Thread starter Hyperreality
    Momentum
The discussion revolves around calculating the final velocity of a boat after a person throws shoes from it, considering the conservation of momentum. Initially, the boat's velocity after the first shoe is expressed as u = mv/(M + m). After the second shoe is thrown, the momentum equations become more complex, leading to confusion about whether the total mass M includes the shoes. Participants explore different expressions for the boat's final velocity, with some suggesting u' = mv(1/(M - m) + 1/(M - 2m)) if M includes the shoes, while others propose adjustments if M does not. The thread highlights the need for clarity on the mass definitions to resolve the discrepancies in the final velocity calculations.
Hyperreality
A peron on a boat with a total mass of M are stationary in the river, the man throws his shoes mass m at a velocity v successive, find the expression for the boat's final velocity.
Here is what I did.
First let u be the velocit of the boat
After the first shoes:
(M + m)u = mv
u = mv(1/(M +m))
After the second shoes:
Change in momentum of the boat = Change in momentum of the shoe
So, Mu'- (M + m)u = mv, but (M + m)u = mv
Therefore Mu' = 2mv and u' = 2mv/M
u + u' = mv(2/M + 1/(M + m)) is the final velocity of the boat.
But the correct answer is mv(1/(M + m) + 1/(M + 2m)), can anyone please tell me where I've got it wrong?
The 2nd shoe ist not at v relative to the water, since it's thrown from a moving boat.
So this is the correct expression?
Mu'- (M + m) = m(u + v)? Because I still can't find the correct expression...
Nor can I reproduce that answer.
There's also something unclear in the problem: It says 'total mass M'. Does that include the shoes, or not?
Let u be the boat velocity after 1st throw.
Let u' be the boat velocity after 2nd throw.
If we assume that M includes the shoes, then
I. (M-m)u = mv
II. (M-2m)u' - (M-m)u = m(v-u)
This leads to
u' = mv(1/(M - m) + 1/(M - 2m)).
Now if M doesn't include the shoes, this will sure mean the transformation
M -> M+2m, yielding
u' = mv(1/(M + m) + 1/M).
I can't see how to get closer to the 'correct' answer.
