A monatomic gas is adiabatically compressed
  • Thread starter Thread starter vorcil
    Compressed Gas
The discussion focuses on the adiabatic compression of a monatomic gas, specifically using the equations PVγ = constant and TVγ - 1 = constant to analyze changes in temperature and root mean square velocity (vrms). Participants clarify that as the volume decreases during adiabatic compression, the temperature increases, leading to an increase in internal energy and vrms. The relationship between temperature and vrms is established as directly proportional, with the final vrms being twice the initial value under specific conditions.
  • Understanding of ideal gas laws and adiabatic processes
  • Familiarity with the equations PVγ = constant and TVγ - 1 = constant
  • Knowledge of root mean square velocity (vrms) and its relation to temperature
  • Basic concepts of thermodynamics, particularly the first law of thermodynamics
  • Study the derivation and implications of the adiabatic condition equations
  • Learn about the relationship between temperature and vrms in detail
  • Explore the concept of mean free path and its dependence on gas volume
  • Investigate the implications of specific heat capacities in ideal gases during adiabatic processes
Students and professionals in physics, particularly those studying thermodynamics, gas laws, and adiabatic processes, will benefit from this discussion.
vorcil
http://img198.imageshack.us/img198/1122/masteringphysicsscreens.jpg
p = ((1/3)*(N/V))*mv^2
vrms = squareroot ((3p)/(N/v))
i tried substituting .125 into the equation to get some numbers, didn't get anything useful
can someone show me the formulas that i have to use, and how to use them? or explain how to solve this problem
cheers
anyone?
If the question called for an actual calculation (I am not sure it does), you would use the adiabatic condition :
PV^{\gamma} = constant or:
TV^{\gamma -1} = constant
In other words, these quantities remain unchanged in an adiabatic process.
Since work is done on the gas, what can you say about the temperature after adiabatic compression (apply first law)? How does vrms relate to temperature?
Would the specific heat Cv change? (remember, the gas is ideal).
What does the mean free path mean? How would it change with reduced volume?
AM
AM
since those values were constant and work is done on the gas, i would expect the temperature to decrease as the volume of the gas decreases to keep the thermal energy constant,
if the temperature decreases, i don't think anything happens to the vrms of the gas, because i looked through the book at the vRms of a gas section and the formulas have nothing to do with temperature (though I'm sure they do)
hangon i'll just google it
ok i found in my book
P = f/a
= 1/3 * N/V * MVrms squared
n/v = p / boltzmanC * temperature
so the volume is inversely proportional to temperature as was my guess, if volume decreases the temperature increases
AM
they are constant?
P = f/a
oh that was the volume not vrms
i found the equation 1/2m * vrms^2 = 3/2 kb t
which means the average root mean square velocity is directly proportional to temperature
3/2 T with kb being boltz's constant, if it decreases, the velocity decreases aswell
bah i failed this question and only got two of the awnsers right
i knew that the heat specific ratio was constant so it was 1,
i got for the first question 2.07 instead of 2.00 and because it's mastering physics i failed that question
i got that from ln(1/.125) for an adiabatic process
the other two awnser for B and C
were lavender = .125 (not sure why the mean free path was the same as the volume percentage it was reduced too
and C was 4,
no idea how the first three awnsers came around for
part a b and c
could someone please show the maths behind it, and the way to those awnsers? I've already finished the question so i just need someone to explain it without asking a question ^ ^
and C was 4,
part a b and c
Since TV^{\gamma - 1} does not change:
T_fV_f^{\gamma-1} = T_iV_i^{\gamma-1}
So:
\frac{T_f}{T_i} = \frac{V_i^{\gamma-1}}{V_f^{\gamma-1}}
since Vi/Vf = 8 and \gamma = 5/3:
\frac{T_f}{T_i} = 8^{2/3} = 4
So the internal energy increases by a factor of 4 and since v_{rms}^2 \propto T, the vrms increases by a factor of 2.
v_{rms-f} = 2v_{rms-i}
AM
So:
AM
Thanks, i actually figured it out in the end by myself :) Almost exactly the same way as you did XD
cheers
