A(n+1) = An + 1/(5^n) sequence
  • Thread starter Thread starter HeartSoul132
    Sequence
HeartSoul132
So, couple sequence questions!
Converge or Diverge?
1.
A(n+1) = An + 1/(5^n) (recursive sequence)
That should read a sub n plus one equals a sub n plus one over 5 to the n
I believe it converges, but would like to be sure.
2. sigma from 1 to infinity of:
(1+5/n)^n
That should read the summation from n equals 1 to infinity of one plus 5 over n quantity to the n-th power. I believe this diverges, but would like to be sure.
Thank you in advance!
If you have any working I can help you more. What tests do you know about?
For a) If A_{n+1} = A_n + \frac{1}{5^n} then A_{n+1} - A_n = \frac{1}{5^n}. Can you prove that this is a Cauchy sequence?
For b) First prove that \lim_{n \rightarrow \infty} (1 + c/n)^n = e^c. Now, if the summand of the series doesn't have a limit of zero, what can you say about the convergence/divergence of the series?
So doesn't b diverge if you use the n term test?
And a converges to what, 6? Not sure what a Cauchy sequence is
For b, are you familiar with the root test?
Nope, but doesn't e^inf not equal 0 meaning it diverges?
The root test says that if the limit of the sequence raised to the power 1/n gives a result which is < 1, the series converges.
If the result is > 1, the series diverges.
If the result = 1, it can't be determined by this test whether the series converges or diverges.
Doesn't n-term work?
I don't know if the test I'm talking about is usually called the n-term test but if the summand doesn't have a limit of zero, then the series diverges.
And a Cauchy sequence is a sequence a_n such that for all epsilon > 0, there is an integer N such that for m,n > N, the following relation holds: |a_m - a_n| < epsilon.
In your case, you can take m = n+1 and so you must show that |a_{n+1} - a_n| = \frac{1}{5^n} &lt; \epsilon
