A permutation group must be a euclidean group?
The discussion centers on the relationship between permutation groups and the Euclidean group in the context of three-dimensional Euclidean space, R(3). Participants explore whether all permutations of elements in R(3) can be classified as a Euclidean group, examining the properties and cardinalities of these groups.
  • One participant asserts that all permutations of elements in R(3) form a permutation group and questions if this group must be the Euclidean group, E(3).
  • Another participant agrees that the permutations form a group but clarifies that the Euclidean group consists only of some of these permutations, suggesting that it is a subgroup of the larger permutation group.
  • A different participant emphasizes that there is only one permutation group, implying a misunderstanding of the previous responses.
  • One participant elaborates that while all permutations form a group, the Euclidean group specifically includes transformations that preserve distances, such as rotations and translations, and does not encompass all possible permutations.
  • This participant provides examples of permutations that would not belong to the Euclidean group, highlighting the difference in cardinality between the two groups.
  • Further, they mention subgroups of the Euclidean group, such as the orthogonal group O(3) and the special orthogonal group SO(3), which are defined by additional constraints on the transformations.
Participants express differing views on the relationship between permutation groups and the Euclidean group. There is no consensus on whether all permutations can be classified as part of the Euclidean group, with some arguing that the Euclidean group is a specific subset of the larger permutation group.
Participants discuss the cardinality of the groups involved, noting that the Euclidean group has a cardinality similar to that of the real numbers, while the group of all permutations is larger. This distinction plays a role in their arguments regarding the nature of these groups.
xiaoxiaoyu
All the perutations of elements in R(3)(three dimension euclidean space) form a permutation group. This group must be E(3)(euclidean group)?
You are right that they will form a permutation group- but (if I follow your question) the Euclidean group will only consist of some of them. Think of a very random permutation, that won't result from an isometry of R^3.
I suppose you can say that the Euclidean group would be a subgroup of it though.
I don't think you follow my question. I mean All the permutations . So there is only one such permutation group.
That's what I thought you meant- so I don't think that you follow my answer:
If you take the group which consists of ALL permutations of elements of R(3) (which is going to be a huge set, of cardinality larger than that of the real numbers), then you will clearly get a group, but what I'm saying is that it won't be the Euclidean group.
The Euclidean group consists of all Euclidean transformations of R(3)- think of taking your copy of R(3), rotating it a bit, reflecting it and/or moving it about by translation. All such transformations will give you the Euclidean group- elements in this group of have the property, for example, that all elements remain the same distance from each other after the transformation.
This clearly isn't so for ALL permutations. Although all Euclidean transformations do describe permutations, I can imagine a permutation e.g. one which just switches (1,0,0) and (0,0,0) and fixes the rest which won't be in the Euclidean group. I suppose you can even see this from the cardinality of the groups- the cardinality of the Euclidean group will only be of order the same as the real numbers (I think), where as ALL permutations will be larger.
A subgroup of the Euclidean group could be where you force the origin to remain fixed. This will give you the orthogonal group O(3). This group is now compact (in a sense, doesn't go off to infinity) because you don't have infinite translations. There is a subgroup of this which is connected, called SO(3), the special orthogonal group. This one doesn't allow "flips", or orientation reversing transformations. All of these things are just permutations, but of a special sort. So, being groups themselves, we could say that they are subgroups of the group of ALL permutations of R(3). e.g. the Euclidean group, I imagine, is just all permutation of R(3) which preserves distances between points.
I hope this longer answer is more clear!
Thank you very much for your explanation!
  • · Replies 26 ·
  • · Replies 32 ·
  • · Replies 22 ·
