A permutation group must be a euclidean group?
xiaoxiaoyu
All the perutations of elements in R(3)(three dimension euclidean space) form a permutation group. This group must be E(3)(euclidean group)?
Mathematics news on Phys.org
You are right that they will form a permutation group- but (if I follow your question) the Euclidean group will only consist of some of them. Think of a very random permutation, that won't result from an isometry of R^3.
I suppose you can say that the Euclidean group would be a subgroup of it though.
I don't think you follow my question. I mean All the permutations . So there is only one such permutation group.
That's what I thought you meant- so I don't think that you follow my answer:
If you take the group which consists of ALL permutations of elements of R(3) (which is going to be a huge set, of cardinality larger than that of the real numbers), then you will clearly get a group, but what I'm saying is that it won't be the Euclidean group.
The Euclidean group consists of all Euclidean transformations of R(3)- think of taking your copy of R(3), rotating it a bit, reflecting it and/or moving it about by translation. All such transformations will give you the Euclidean group- elements in this group of have the property, for example, that all elements remain the same distance from each other after the transformation.
This clearly isn't so for ALL permutations. Although all Euclidean transformations do describe permutations, I can imagine a permutation e.g. one which just switches (1,0,0) and (0,0,0) and fixes the rest which won't be in the Euclidean group. I suppose you can even see this from the cardinality of the groups- the cardinality of the Euclidean group will only be of order the same as the real numbers (I think), where as ALL permutations will be larger.
A subgroup of the Euclidean group could be where you force the origin to remain fixed. This will give you the orthogonal group O(3). This group is now compact (in a sense, doesn't go off to infinity) because you don't have infinite translations. There is a subgroup of this which is connected, called SO(3), the special orthogonal group. This one doesn't allow "flips", or orientation reversing transformations. All of these things are just permutations, but of a special sort. So, being groups themselves, we could say that they are subgroups of the group of ALL permutations of R(3). e.g. the Euclidean group, I imagine, is just all permutation of R(3) which preserves distances between points.
I hope this longer answer is more clear!
Thank you very much for your explanation!
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
