A point in a proof about sequential compactness
  • Thread starter Thread starter radou
    Point Proof
radou
Homework Helper
OK, so I'm going through the proof of a theorem in Munkres:
Theorem 28.2. If X is a metrizable space, then the following statements are equivalent:
(1) X is compact
(2) X is limit point compact
(3) X is sequentially compact
There's an argument in (2) ==> (3) which I don't quite get. I'll quote directly:
Assume X is limit point compact. Given a sequence (xn) of points in X, consider the set A = {xn : n is a positive integer}. If the set is finite, then there is a point x such that x = xn, for infinitely many values of n. In this case, the sequence (xn) has a constant subsequence, and therefore converges trivially.
OK, if the set A is finite, we have a finite sequence. By definition, a subsequence yn of a given sequence is obtained from the original one by taking an increasing sequence of positive integers n1 < n2 < n3 < ... and defining yi = xni.
I don't understand how we obtained a constant infinite sequence from a finite sequence?
Thanks for any help on this one, it's really bugging me.
No, I think you interpreted that wrong. A sequence ALWAYS has infinitely many elements. But if A is finite, then this sequence can only assume finitely many elements.
Take the sequence x_n=(-1)^n. This has infinitely many elements (which coincide). But the sequences image is finite.
In the proof we have that A is finite. So the sequence (although having an infinity of elements) has a finite image. So there has to be inifitely many elements of the sequence which are sent to the same element. So we have found an infinite subsequence which is constant.
I wish I could explain this better...
What micromass said is correct. What you have to understand is that there are infinitely many elements of a sequence; however, if that sequence is taken as a set, then the set may be finite. I'll steal his example. Consider the sequence x_n = (-1)^n. That sequence looks like -1,1,-1,1,... for all natural numbers n, and since there are infinitely many natural numbers, the sequence is infinite. However, as a set, the sequence is \{-1,1\}. So there exists some x \in x_n such that x = x_n for infinitely many values of n. Note that it doesn't say for all n, or for all n > some N, but for infinitely many. In this example, if you let x = 1, then x = x_2,x_4,... = x_{2n}. Clearly there are infinitely many such instances of this occurring.
This is a subsequence, and since it is constant, it converges. If there is any way to form a constant subsequence out of a sequence, then it converges, as is the case for a periodic sequence like this.
n.b.: Obviously a sequence taken as a set is not always finite. Consider a_n = \frac{1}{n}. As a set, this is \{1,1/2,1/3,...\}.
Gee, this was really simple. Thanks a lot :)
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
