A problem in limit of a complex function
cng99
I'm a newbie at complex analysis.
Find:
lim \frac{\bar{z}^{2}}{z}
z→0
2. The attempt at a solution
L'Hospital rule gives the answer in no time. But how do you solve without it?
Well, I think it would help if you read up on how to do limits in complex analysis first.
You basically have to find out the limit as x->0 and y->0. You have to do it twice.
For e.g. as x->0 and then y->0 (1) -- then y->0 and then x->0 (2), this way you might find there are two different limits; this means the limit does not exist.
But the answer is zero.
Also can you suggest me some good self-study material to learn complex calculus? I'm good at real number calculus, and I started reading this book called 'Complex Variables Demystified' by David McMohan. But it's the only one I have.
Yes, well when you calculate this limit you will find out it is zero. It matches.
I'm sure some more experienced users can suggest much better material. I too am fairly new to this stuff. There are plenty of online notes, books, etc though.
Thanks a lot.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
