A pulley system with two pulleys and two suspended masses
54 replies · 4K views
member 731016
Pls see below
Pls see below
For this problem,
The solution is,
However, how do they know the block B will move up and block A will move down? The masses of each are not given so could be the other way round if ##m_b > m_a##?
Also how do they know that if block B moves up by 1cm, block A will move down by 2cm?
Many thanks!
The problem states that the masses are equal and the solution is based on that.
Thank you for your reply @kuruman !
Sorry I did not see that! I will try the problem again.
Many thanks!
That is a matter of 'counting': in the picture you see three lengths of cord. Think of the situation that block A is all the way down: by then A has dropped by two lengths, whereas B has gone up by only one length.
Thank you for your reply @BvU!
I think I might see what you mean from intuition, is there way to prove this thought?
Many thanks!
Many thanks!
Write the total length of the inextensible rope ##L##, In terms of all the other lengths of each section. There will be a couple more steps, but that is where you start.
Yes ! The overwhelming beauty of physics: The experiment decides !
Thank you for your reply @erobz ! That diagram is quite helpful :)
## L = l + s + 2.5 \times purple~semicircle##
Many thanks!
Many thanks!
Sorry, I shouldn't have drawn that top section purple, it could be any length. I'll update the image.
1) just assign a random variable to each length that is not already labeled.
2) you are missing some length of rope in that sum.
1) just assign a random variable to each length that is not already labled
Is the ok for the variables?
Many thanks!
From the diagram it looks like ##c = b##, but would you like me to leave it like that @erobz ?
Many thanks!
##L = a + s + b + c + l##
Many thanks!
ok, but you are still missing a length of rope there.
Sorry should be ##L = a + 2s + b + c + l## and assuming that the pulleys are the same size as the rope is taut, then ##c = b ## so simplifying gives ##L = a + 2s + 2b + l##
Many thanks!
Many thanks!
Great! Now identify the only variables that change in that equation when the blocks move.
The variables that change are ##l## and ##s##
Many thanks!
Many thanks!
I guess they are functions of time then?
Many thanks!
Many thanks!
Don't worry about that just yet.
So ##l## and ##s## are the only length that can change. Apply a change to each of the variables.
For instance if a varianle was ##z## we would apply a change by adding ##\Delta z## to it. etc...
Write the new equation.
The change for each length is
##\Delta l##
##\Delta s##
Which in the original equation is
##L = a + 2\Delta s + 2b + \Delta l##Many thanks!
##\Delta l##
##\Delta s##
Many thanks!
So what is the new equation? Rember a variable that changes goes from ##z \to z+ \Delta z##.
I this this equation,
Can also be expressed as##L_i = L_f##
## a + 2s_i + 2b + l_i = a + 2s_f + 2b + l_f##
## 2s_i + l_i =2s_f+ l_f##
Many thanks!
Thank you for your reply @erobz!
Do you mean
##z_i = z_f + \Delta z##?
If you want I could edit post #23 to use that notation. This is giving me conservation of string vibes I remember sometime talking about it on Discord.
Many thanks!
Do you mean
Many thanks!
you don't need the subscripts. Its just saying you take what was labeled ##z## in the original eq. and replace it with ##z + \Delta z##.
I think @erobz that,
## L_i = 2s_i + l_i =2s_f+ l_f = L_f##
is really just a conservation of string statement, correct?
Many thanks!
Oh ok thank you for your reply @erobz !
I'm not too familiar with that notation. I will change to that notation.
Many thanks!
Many thanks!
I believe it's the standard we approach stuff in Calculus.
Hi @erobz ,
Is the reason why you used arrows for this ##z \to z+ \Delta z## because if you use equal sign then
##z = z+ \Delta z##
##z = z+ z_f - z_i##
##z_i = z_f##
Oh which is conservation of the quantity z anyway!
Many thanks!
