A question about centrifugal force
When discussing centrifugal force on a rotating platform, it's important to clarify that "1g" refers to gravitational acceleration, not force. The force acting on an object depends on the rate of rotation and its distance from the axis. As the object moves outward on the platform, the speed and radius increase, leading to greater forces at the edges compared to the center. Additionally, friction between the object and the platform must be considered, especially if maximum rotation speed is relevant. Understanding these dynamics is crucial for accurately assessing the forces experienced on the platform.
Grytviken
Say the force is 1g for an object rotating around an axis. If the object is a platform that is facing the center how would forces act on an item placed at different areas on the platform?
Thanks.
Thanks.
This question is rather ... er .. vague.
First of all, "1 g" is mass, not "force" or weight.
Secondly, to know how much force is acting on an object "rotating" around an axis, one needs to know the rate of rotation as well. A mass of 1 g rotating around an axis requires different amount of force for different rotation speed, even if it was placed at the same distance away from the axis of rotation.
Added to the complication, you are placing this on a platform, meaning frictional force between the object and the platform how comes into play. So now, the coefficient of static friction is also needed IF the maximum speed of rotation is also something that needs to be discovered.
Zz.
Zz.
I think he might be referring to gravitational force, as in g-force. 1G is the amount of force we feel on Earth (approximate), etc.
G is a unit of acceleration, not force.
Heh my mistake. I always seem to forget that force is the product of acceleration AND mass.
g is a rate of acceleration, G is a gravitational constant.
The rate of acceleration corresponds to speed2 / r. If the platform is flat, but orbiting around some central point, then speed and radius will be greater at the leading and trailing edges of the platform as opposed to the center.
And angle.
Standing at the edge of the platform, the platform will be perceived as tilted from horizontal. (Your head and body will line up with the axis, so under your feet the platform will feel sloped, like you're going to slip off the edge.)
Thx especially to those who understood my question! I won't call it a force anymore alright :)
I'm talking about units. g = 1G.
