A Question About Newton's Third Law
Newton's Third Law applies in Croquet when a player strikes a static ball, transferring momentum to it. The force from the club gives the first ball momentum, which then transfers to the second ball upon impact. This interaction illustrates momentum transfer, where the first ball's force on the second ball results in a reaction force that stops the first ball. Therefore, both balls experience forces in accordance with Newton's Third Law. Understanding this principle is essential for grasping the dynamics of the game.
arevolutionist
Please excuse the newbieness of this question. I recently began studying physics. Does Newton's third law apply in the game of Croquet when one applies force to a static ball between the club and a second ball, thus causing the second ball to continue the force applied by the static ball?
Science news on Phys.org
Actually it's a question of momentum transfer. In this case, force is the means by which momentum is transferred. Yes, Newton's Third Law does apply; indeed it is always true. The force applied by the club gives the first ball momentum, and the first ball applies a force to the second ball, thus transferring its momentum to that ball. But the reaction force of the second ball (via Newton's Third Law) stops the first ball.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
